A systematic approach towards security in Fog computing: assets, vulnerabilities, possible countermeasures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software: Practice and Experience Année : 2020
Fog computing is an emerging paradigm in the IoT space, consisting of a middle computation layer, sitting between IoT devices and Cloud servers. Fog computing provides additional computing, storage and networking resources in close proximity to where data is being generated and/or consumed. As the Fog layer has direct access to data streams generated by IoT devices and responses/commands sent from the Cloud, it is in a critical position in terms of security of the entire IoT system. Currently, there is no specific tool or methodology for analysing the security of Fog computing systems in a comprehensive way. Generic security evaluation procedures applicable to most information technology products are time consuming, costly and badly suited to the Fog context. In this article, we introduce a methodology for evaluating the security of Fog computing systems in a systematic way. We also apply our methodology to a generic Fog computing system, showcasing how it can be purposefully used by security analysts and system designers.
main.pdf (425.52 Ko) Télécharger le fichier
hal-02441639 , version 1 (16-01-2020)
Mozhdeh Farhadi, Jean-Louis Lanet, Guillaume Pierre, Daniele Miorandi. A systematic approach towards security in Fog computing: assets, vulnerabilities, possible countermeasures. Software: Practice and Experience, 2020, 50 (6), pp.973-997. ⟨10.1002/spe.2804⟩. ⟨hal-02441639⟩
293 Consultations
405 Téléchargements
