A DtN approach to the mathematical and numerical analysis in waveguides with periodic outlets at infinity - Archive ouverte HAL Access content directly
Journal Articles Pure and Applied Analysis Year : 2021
(1) , (1) , (2)
1
2
We consider the time harmonic scalar wave equation in junctions of several different periodic half-waveguides. In general this problem is not well posed. Several papers propose radiation conditions, i.e. the prescription of the behaviour of the solution at the infinities. This ensures uniqueness - except for a countable set of frequencies which correspond to the resonances- and yields existence when one is able to apply Fredholm alternative. This solution is called the outgoing solution. However, such radiation conditions are difficult to handle numerically. In this paper, we propose so-called transparent boundary conditions which enables us to characterize the outgoing solution. Moreover, the problem set in a bounded domain containing the junction with this transparent boundary conditions is of Fredholm type. These transparent boundary conditions are based on Dirichlet-to-Neumann operators whose construction is described in the paper. On contrary to the other approaches, the advantage of this approach is that a numerical method can be naturally derived in order to compute the outgoing solution. Numerical results illustrate and validate the method.
VersionSoumise.pdf (7.58 Mo) Télécharger le fichier
Dates and versions
hal-02444754 , version 1 (29-09-2020)
Identifiers
Cite
Sonia Fliss, Patrick Joly, Vincent Lescarret. A DtN approach to the mathematical and numerical analysis in waveguides with periodic outlets at infinity. Pure and Applied Analysis, 2021, ⟨10.2140/paa.2021.3.487⟩. ⟨hal-02444754⟩
132 View
156 Download
Share
