TPFA Finite Volume Approximation of Wasserstein Gradient Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Numerous infinite dimensional dynamical systems arising in different fields have been shown to exhibit a gradient flow structure in the Wasserstein space. We construct Two Point Flux Approximation Finite Volume schemes to discretize these problems preserving their variational structure and obtaining second order accuracy in space. The choice of the discrete solver plays an important role in designing these schemes for robustness purposes. We present two applications to test the scheme and show its order of convergence.
LJKO_ipm_hal.pdf (590.29 Ko) Télécharger le fichier
hal-02444833 , version 1 (19-01-2020)
hal-02444833 , version 2 (26-05-2020)
Andrea Natale, Gabriele Todeschi. TPFA Finite Volume Approximation of Wasserstein Gradient Flows. 2020. ⟨hal-02444833v1⟩
202 Consultations
136 Téléchargements
