Open-Source 4G Experimental Setup - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
In this work, we show how to set up a cellular LTE network for wireless experimentation and measurement, relying on commodity hardware and open-source software. We first deploy a complete LTE network on a single laptop and an SDR hardware. Then, we use it to evaluate the reception performance of a commercial smartphone. In the end, we propose a calibration technique which allows using a smartphone as a wireless power measurement tool by reducing the root-mean-square error of the RSSI, with respect to a reference power measured with a specialized spectrum analyzer, from 6.4 dBm to 2.4 dBm.
main.pdf (238.65 Ko) Télécharger le fichier
calib_result.pdf (22.48 Ko) Télécharger le fichier
experimental.pdf (70.71 Ko) Télécharger le fichier
heatmap_h.pdf (25.34 Ko) Télécharger le fichier
process.pdf (37.65 Ko) Télécharger le fichier
hal-02445762 , version 1 (20-01-2020)
hal-02445762 , version 2 (14-04-2020)
  • HAL Id : hal-02445762 , version 1
Yanis Boussad, M Naoufal Mahfoudi, Arnaud Legout, Fabien Ferrero, Leonardo Lizzi, et al.. Open-Source 4G Experimental Setup. [Research Report] Inria & Université Cote d'Azur, CNRS, I3S, Sophia Antipolis, France. 2020. ⟨hal-02445762v1⟩
278 Consultations
269 Téléchargements
