Open-Source 4G Experimental Setup (Report)
In this work, we show how to set up a cellular LTE network for wireless experimentation and measurement, relying on commodity hardware and open-source software. We first deploy a complete LTE network on a single laptop and an SDR hardware. Then, we use it to evaluate the reception performance of a commercial smartphone. In the end, we propose a calibration technique which allows using a smartphone as a wireless power measurement tool by reducing the root-mean-square error of the RSSI, with respect to a reference power measured with a specialized spectrum analyzer, from 6.4 dBm to 2.4 dBm.
main.pdf (226.73 Ko)
Télécharger le fichier
calib_result.pdf (22.48 Ko)
experimental.pdf (70.71 Ko)
heatmap_h.pdf (25.34 Ko)
process.pdf (37.65 Ko)
