DL-LITER in the Light of Propositional Logic for Decentralized Data Management, IJCAI, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00429710
Complexity of Answering Queries Using Materialized Views, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00802873
Foundations of Databases, 1995. ,
Towards Scalable Hybrid Stores: Constraint-Based Rewriting to the Rescue, SIGMOD, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02070827
Querying XML Sources Using an Ontology-Based Mediator, CoopIS, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01124731
Integrating Ontologies and Thesauri to Build RDF Schemas, ECDL, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01124461
Integrating ontologies and thesauri for RDF schema creation and metadata querying, Int. J. on Digital Libraries, vol.3, p.3, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00948932
, The Description Logic Handbook: Theory, Implementation, and Applications, 2003.
Graal: A Toolkit for Query Answering with Existential Rules, RuleML, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01172063
Mixed-instance querying: a lightweight integration architecture for data journalism, VLDB, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01321201
A Generalized Framework for Ontology-Based Data Access, 2018. ,
Reformulation-Based Query Answering for RDF Graphs with RDFS Ontologies, ESWC, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02051413
Rewriting-Based Query Answering for Semantic Data Integration Systems, BDA (informal publication only, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01927282
Optimizing Reformulation-based Query Answering in RDF, EDBT, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01143068
A general Datalogbased framework for tractable query answering over ontologies, PODS, 2009. ,
Ontop: Answering SPARQL queries over relational databases, Semantic Web, vol.8, p.3, 2017. ,
The MASTRO system for ontology-based data access, Semantic Web, vol.2, p.1, 2011. ,
Using OWL in Data Integration, Semantic Web Information Management -A Model-Based Perspective, 2009. ,
Query Processing under GLAV Mappings for Relational and Graph Databases, PVLDB, vol.6, 2012. ,
A Semantic Network Approach to Semi-Structured Documents Repositories, ECDL, 1997. ,
Using Ontologies for Semantic Data Integration, A Comprehensive Guide Through the Italian Database Research Over the Last 25 Years, vol.31, 2018. ,
MARS: A System for Publishing XML from Mixed and Redundant Storage, VLDB, 2003. ,
Principles of Data Integration, 2012. ,
, The BigDAWG Polystore System. SIGMOD, vol.44, 2015.
Learning Commonalities in SPARQL, ISWC, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01572691
Navigational Plans for Data Integration, 1999. ,
The TSIMMIS Approach to Mediation: Data Models and Languages, J. Intell. Inf. Syst, vol.8, issue.2, 1997. ,
The Use of CARIN Language and Algorithms for Information Integration: The PICSEL System, Int. J. Cooperative Inf. Syst, vol.9, p.4, 2000. ,
Efficient query answering against dynamic RDF databases, EDBT, 2013. ,
Answering queries using views: A KRDB perspective for the semantic Web, ACM TOIT, vol.4, p.3, 2004. ,
Answering Queries Using Views: A Survey, The VLDB Journal, vol.10, 2001. ,
Ontology-Based Data Access to Slegge, ISWC, 2017. ,
Answering SPARQL Queries over Databases under OWL 2 QL Entailment Regime, ISWC, 2014. ,
Cost-Driven Ontology-Based Data Access, ISWC, 2017. ,
Data Integration: A Theoretical Perspective, PODS, 2002. ,
Querying Heterogeneous Information Sources Using Source Descriptions, VLDB, 1996. ,
Data Model and Query Evaluation in Global Information Systems, J. Intell. Inf. Syst, vol.5, 1995. ,
Answering XML Queries on Heterogeneous Data Sources, VLDB, 2001. ,
Ontological Query Answering with Existential Rules, RR, 2011. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00618296
Optimizing query rewriting in ontology-based data access, EDBT, 2013. ,
Linking Data to Ontologies, J. Data Semantics, vol.10, 2008. ,
MiniCon: A scalable algorithm for answering queries using views, VLDB J, vol.10, 2001. ,
Ontology-Based Data Access: Ontop of Databases, ISWC, 2013. ,
OBDA: Query Rewriting or Materialization? In Practice, Both!, ISWC, 2014. ,
AGGREGO SEARCH: Interactive Keyword Query Construction, EDBT, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01063422
, W3C. 2013. SPARQL 1.1 Query Language
, W3C. 2014. RDF 1.1 Concepts and Abstract Syntax
, W3C. 2014. RDF 1.1 Semantics
Mediators in the Architecture of Future Information Systems, IEEE Computer, vol.25, p.3, 1992. ,
