Abstract : We propose and analyze non-overlapping Schwarz algorithms for the domain decomposition of the unsteady incompressible Navier-Stokes problem with Discrete Duality Finite Volume discretizations. The design of suitable transmission conditions for the velocity and the pressure is a crucial issue. We establish the well-posedness of the method and the convergence of the iterative process, pointing out how the numerical fluxes influence the asymptotic problem which is intended to be a discretization of the Navier-Stokes equations on the entire computational domain. Finally we perform some numerical tests to illustrate the behavior of the algorithm.
