Discrete duality finite volume schemes for Leray-Lions type elliptic problems on general 2D-meshes, Numer. Methods PDEs, vol.23, issue.1, pp.145-195, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00005779
A new cement to glue non-conforming grids with Robin interface conditions: The finite volume case, Numer. Math, vol.92, issue.4, pp.593-620, 2002. ,
Towards optimized schwarz methods for the Navier-Stokes equations, J. Sci. Comput, vol.66, issue.1, pp.275-295, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00982087
Non-overlapping Schwarz algorithm for solving 2d m-DDFV schemes, IMA J. Numer. Anal, vol.30, issue.4, pp.1062-1100, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00307185
Inf-Sup stability of the Discrete Duality Finite Volume method for the 2D Stokes problem, Math. Comput, vol.84, pp.2705-2742, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00795362
On the stabilization of finite element approximations of the Stokes equations, Efficient solutions of elliptic systems, vol.10, pp.11-19, 1984. ,
Finite volume schemes for non-coercive elliptic problems with Neumann boundary conditions, IMA J. Numer. Anal, vol.31, pp.61-85, 2011. ,
The Lions domain decomposition algorithm on nonmatching cell-centred finite volume meshes, IMA J. Numer. Anal, vol.24, issue.3, pp.465-490, 2004. ,
Convergence rate of a finite volume scheme for a two dimensional convection-diffusion problem, ESAIM: Math. Mod. Numer. Anal, vol.33, issue.3, pp.493-516, 1999. ,
Développement de méthodes de volumes finis pour la mécanique des fluides, 2007. ,
A finite volume method for the Laplace equation on almost arbitrary two-dimensional grids, ESAIM: Math. Mod. Numer. Anal, vol.39, issue.6, pp.1203-1249, 2005. ,
A Discrete Duality Finite Volume discretization of the vorticityvelocity-pressure formulation of the 2D Stokes problem on almost arbitrary two-dimensional grids, Numer. Methods PDEs, pp.1-30, 2015. ,
Finite volume schemes for diffusion equations: Introduction to and review of modern methods, Math. Models Methods Appl. Sci, vol.24, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00813613
Finite volume methods, Handbook of numerical analysis, pp.715-1022, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-02100732
On a stabilized colocated finite volume scheme for the Stokes problem, ESAIM: Math. Mod. Numer. Anal, vol.40, issue.3, pp.501-527, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00793601
Convergence analysis of a colocated finite volume scheme for the incompressible Navier-Stokes equations on general 2D or 3D meshes, SIAM J. Numer. Anal, vol.45, issue.1, pp.1-36, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00004841
Optimized Schwarz waveform relaxation methods for advection reaction diffusion problems, SIAM J. Numer. Anal, vol.45, issue.2, pp.666-697, 2007. ,
Optimized Schwarz methods for anisotropic diffusion with Discrete Duality Finite Volume discretizations, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01782357
A new cement to glue nonconforming grids with Robin interface conditions: the finite element case, Lect. Notes Comput. Sci. Eng, vol.40, pp.259-266, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00112937
Numerical analysis of the DDFV method for the Stokes problem with mixed Neumann/Dirichlet boundary conditions, Proceeding of the 8th international symposium on Finite Volumes for Complex Applications, vol.199, pp.361-369 ,
URL : https://hal.archives-ouvertes.fr/hal-01502397
, , 2017.
DDFV method for Navier-Stokes problem with outflow boundary conditions, Numer. Math, vol.142, issue.1, pp.55-102, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01842129
Convergence study of a DDFV scheme for the Navier-Stokes equations arising in the domain decomposition setting, Finite Volumes for Complex Applications IX, p.2020, 2020. ,
A discontinuous Galerkin method with nonoverlapping domain decomposition for the Stokes and Navier-Stokes problems, Math. Comput, vol.74, pp.53-84, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00020211
A finite volume method for the approximation of diffusion operators on distorted meshes, J. Comput. Phys, vol.160, issue.2, pp.481-499, 2000. ,
Approximation of diffusion operators with discontinuous tensor coefficients on distorted meshes, Comput. Methods Appl. Mech. Engrg, vol.192, pp.1939-1959, 2003. ,
A finite volume Ventcell-Schwarz algorithm for advection-diffusion equations, SIAM J. Numer. Anal, vol.52, issue.3, pp.1269-1291, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01271249
Artificial boundary conditions for incompressible flows, SIAM J. Math. Anal, vol.20, pp.308-353, 1989. ,
Numerical calculation of time-dependent viscous incompressible flow of fluid with free surface, Physics of Fluids, vol.8, p.2182, 1965. ,
Reference values for drag and lift of a two-dimensional time-dependent flow around a cylinder, Int. J. Numer. Meth. Fluids, vol.44, issue.7, pp.777-788, 2004. ,
Schémas Volumes Finis en mécanique des fluides complexes, 2010. ,
Stabilized DDFV schemes for Stokes problem with variable viscosity on general 2D meshes, Numer. Methods PDEs, vol.27, issue.6, pp.1666-1706, 2011. ,
Stabilized DDFV schemes for the incompressible Navier-Stokes equations, Finite Volumes for Complex Applications VI, Problems & Perspectives, pp.605-612, 2011. ,
On the Schwarz alternating method. III. A variant for nonoverlapping subdomains, Third International Symposium on Domain Decomposition Methods for Partial Differential Equations, pp.202-223, 1990. ,
A nonoverlapping domain decomposition method for stabilized finite element approximations of the Oseen equations, J. Comput. Appl. Math, vol.132, issue.2, pp.211-236, 2001. ,
Über einen grenzübergang durch alternierendes verfahren, Vierteljahrsschrift der Naturforschenden Gesellschaft in Zurich, vol.15, pp.272-286, 1870. ,
Benchmark computations of laminar flow around a cylinder, Flow Simulation with High-Performance Computers, vol.48, pp.547-566, 1996. ,
On nonoverlapping domain decomposition methods for the incompressible Navier-Stokes equations, ESAIM: Math. Mod. Numer. Anal, vol.39, issue.6, pp.1251-1269, 2005. ,
