Opetopic algebras III: Presheaf models of homotopy-coherent opetopic algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
For Λ the category of free opetopic algebras, we construct a model structure à la Cisinski on the category of presheaves over Λ, and show that is is equivalent to opetopic complete Segal spaces. This generalizes the results of Joyal and Tierney in the simplicial case, and of Cisinski and Moerdijk in the planar dendroidal case.
main.pdf (353.87 Ko) Télécharger le fichier
hal-02448208 , version 1 (22-01-2020)
  • HAL Id : hal-02448208 , version 1
Cédric Ho Thanh, Chaitanya Leena Subramaniam. Opetopic algebras III: Presheaf models of homotopy-coherent opetopic algebras. 2020. ⟨hal-02448208⟩
56 Consultations
67 Téléchargements
