TinyMT32 Pseudorandom Number Generator (PRNG) (RFC 8682) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2020
This document describes the TinyMT32 Pseudorandom Number Generator (PRNG), which produces 32-bit pseudorandom unsigned integers and aims at having a simple-to-use and deterministic solution. This PRNG is a small-sized variant of the Mersenne Twister (MT) PRNG. The main advantage of TinyMT32 over MT is the use of a small internal state, compatible with most target platforms that include embedded devices, while keeping reasonably good randomness that represents a significant improvement compared to the Park-Miller Linear Congruential PRNG. However, neither the TinyMT nor MT PRNG is meant to be used for cryptographic applications.
rfc8682.pdf (126.93 Ko) Télécharger le fichier
hal-02449210 , version 1 (22-01-2020)
  • HAL Id : hal-02449210 , version 1
Masahiko Saito, Makoto Matsumoto, Vincent Roca, Emmanuel Baccelli. TinyMT32 Pseudorandom Number Generator (PRNG) (RFC 8682). 2020. ⟨hal-02449210⟩
208 Consultations
156 Téléchargements
