Theoretical basis of the Organic Rankine Cycle, pp.3-24, 2017. ,
Organic Rankine Cycle Power Systems: From the Concept to Current Technology, Applications, and an Outlook to the Future, Journal and Engineering for Gas Turbines and Power, vol.137, 2015. ,
On optimum design in fluid mechanics, Journal of Fluid Mechanics, vol.64, issue.1, pp.97-110, 1974. ,
Experimental evidence of non-ideal compressible effects in expanding flow of a high molecular complexity vapor, Experiments in Fluids, vol.59, issue.8, 2018. ,
Adjoint method for shape optimization in real-gas flow applications, ASME Journal of Engineering for Gas Turbines and Power, vol.137, issue.3, 2015. ,
Fully turbulent discrete adjoint solver for non-ideal compressible flow applications, Journal of the Global Power and Propulsion Society, vol.1, p.1, 2017. ,
Adjoint-based fluid dynamic design optimization in quasi-periodic unsteady flow problems using a harmonic balance method, Journal of Computational Physics, 2018. ,
Shape optimization of an Organic Rankine Cycle radial turbine nozzle, Journal and Engineering for Gas Turbines and Power, vol.135, 2013. ,
High-fidelity shape optimization of non-conventional turbomachinery by surrogate evolutionary strategies, Journal of Turbomachinery, vol.141, issue.8, pp.81010-081010, 2019. ,
Evolutionary Optimization of Centrifugal Nozzles for Organic Vapours, Journal of Physics: Conference Series, vol.821, 2017. ,
Fluid dynamic design of Organic Rankine Cycle turbines, pp.253-297, 2017. ,
Robust adjoint-based shape optimization of supersonic turbomachinery cascades, Turbine Technical Conference and Exposition, pp.2-39, 2014. ,
Efficient reanalysis techniques for robust topology optimization, Computer Methods in Applied Mechanics and Engineering, pp.217-231, 2012. ,
Topology optimization under uncertainty via nonintrusive polynomial chaos expansion, Computer Methods in Applied Mechanics and Engineering, vol.318, pp.120-147, 2017. ,
Sequential approximate optimization for design under uncertainty problems utilizing kriging metamodeling in augmented input space, Computer Methods in Applied Mechanics and Engineering, vol.315, pp.369-395, 2017. ,
The use of metamodeling techniques for optimization under uncertainty. Structural and Multidisciplinary Optimization, vol.25, pp.99-116, 2003. ,
A global robust optimization using kriging based approximation model, JSME International Journal Series C Mechanical Systems, Machine Elements and Manufacturing, vol.49, issue.3, pp.779-788, 2006. ,
Simultaneous kriging-based estimation and optimization of mean response, Journal of Global Optimization, vol.55, issue.2, pp.313-336, 2013. ,
URL : https://hal.archives-ouvertes.fr/emse-00674460
Global Optimization of Stochastic Black-Box Systems via Sequential Kriging Meta-Models, Journal of Global Optimization, vol.34, issue.3, pp.441-466, 2006. ,
Noisy Expected Improvement and on-line computation time allocation for the optimization of simulators with tunable fidelity, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00489321
Tsi metamodels-based multi-objective robust optimization, vol.30, pp.1032-1053, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00807652
Robust optimization of an organic rankine cycle for heavy duty engine waste heat recovery, 4th International Seminar on ORC Power SystemsSeptember 13-15th 2017POLITECNICO DI MILANOBOVISA CAMPUSMILANO, vol.129, pp.66-73, 2017. ,
Robust optimization of supersonic orc nozzle guide vanes, Journal of Physics: Conference Series, vol.821, issue.1, p.12014, 2017. ,
Rare event estimation using polynomial-chaos kriging, ASCE-ASME Journal of Risk and Uncertainty in Engineering Systems, Part A: Civil Engineering, vol.3, issue.2, p.4016002, 2016. ,
A tutorial on bayesian optimization of expensive cost functions, with application to active user modeling and hierarchical reinforcement learning, 2010. ,
Real-gas effects in organic rankine cycle turbine nozzles, Journal of Propulsion and Power, vol.24, issue.2, pp.282-294, 2008. ,
Stanford University Unstructured (SU2): An open-source integrated computational environment for multi-physics simulation and design, 51st AIAA Aerospace Sciences Meeting and Exhibit, 2013. ,
Performance optimizations for scalable implicit {RANS} calculations with {SU2}, Computers & Fluids, vol.129, pp.146-158, 2016. ,
Su2: the open-source software for non-ideal compressible flows, NICFD 2016: 1st International Seminar on Non-Ideal Compressible-Fluid Dynamics for Propusion & Power, 2016. ,
Experimental assessment of the open-source su2 cfd suite for orc applications, Energy Procedia, pp.256-263, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01675644
Extension of the su2 open source cfd code to the simulation of turbulent flows of fuids modelled with complex thermophysical laws, AIAA Paper, 2015. ,
Approximate riemann solvers, parameter vectors, and difference schemes, J. Comput. Phys, vol.43, issue.2, pp.357-372, 1981. ,
Generalized flux-vector splitting and roe average for an equilibrium real gas, J. Comput. Phys, vol.89, p.276, 1990. ,
Roe linearization for the van der Waals gas, J. Comput. Phys, vol.175, pp.50-78, 2002. ,
Zonal two equation kw turbulence models for aerodynamic flows, 23rd fluid dynamics, plasmadynamics, and lasers conference, p.2906, 1993. ,
Nonreflecting boundary conditions for euler equation calculations, AIAA journal, vol.28, issue.12, pp.2050-2058, 1990. ,
Mesh deformation based on radial basis function interpolation, Computers & structures, vol.85, pp.784-795, 2007. ,
Fundamentals of computer aided geometric design, 1993. ,
Curves and Surfaces for CAGD: A Practical Guide, 2002. ,
Gaussian Processes for Machine Learning, 2006. ,
A gaussian process framework in python ,
The design and analysis of computer experiments, 2013. ,
New routes from minimal approximation error to principal components, Neural Processing Letters, vol.27, issue.3, pp.197-207, 2008. ,
, , 2018.
Investigation of the Unsteady Aerodynamics in a Transonic Turbine Stage, ASME J. Turbomach, vol.123, issue.1, pp.81-89, 2001. ,
Wake, Shock, and Potential Field Interactions in a 1.5 Stage Turbine-Part I: Vane-Rotor and Rotor-Vane Interaction, ASME J. Turbomach, vol.125, issue.1, pp.33-39, 2003. ,
Surrogate-based aerodynamic shape optimization of a wing-body transport aircraft configuration, Symposium on AeroStructures, pp.257-282, 2015. ,
Assessment of deterministic shape optimizations within a stochastic framework for supersonic organic rankine cycle nozzle cascades, Journal of Engineering for Gas Turbines and Power, vol.141, issue.7, pp.71019-071019, 2019. ,
Surrogate-Assisted Bounding-Box Approach for Optimization Problems with Approximated Objectives, Inria, 2018. ,
Surrogate-Assisted Bounding-Box Approach Applied to Constrained Multi-Objective Optimisation Under Uncertainty ,
URL : https://hal.archives-ouvertes.fr/hal-01897399
, , 2018.
