Sparse Interpolation in Terms of Multivariate Chebyshev Polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2022
Michael F. Singer
  • Fonction : Auteur
  • PersonId : 1063598
Sparse interpolation refers to the exact recovery of a function as a short linear combination of basis functions from a limited number of evaluations. For multivariate functions, the case of the monomial basis is well studied, as is now the basis of exponential functions. Beyond the multivariate Chebyshev polynomial obtained as tensor products of univariate Chebyshev polynomials, the theory of root systems allows to define a variety of generalized multivariate Chebyshev polynomials that have connections to topics such as Fourier analysis and representations of Lie algebras. We present a deterministic algorithm to recover a function that is the linear combination of at most r such polynomials from the knowledge of r and an explicitly bounded number of evaluations of this function.
HubertSinger2020_01.pdf (1.36 Mo) Télécharger le fichier
hal-02454589 , version 1 (24-01-2020)
Evelyne Hubert, Michael F. Singer. Sparse Interpolation in Terms of Multivariate Chebyshev Polynomials. Foundations of Computational Mathematics, 2022, 22 (6), pp.1801-1862. ⟨10.1007/s10208-021-09535-7⟩. ⟨hal-02454589⟩
176 Consultations
220 Téléchargements
