Conference papers
On the saddlepoint approximation of the dependence testing bound in memoryless channels
Dadja Anade 1 Jean-Marie Gorce 1 Philippe Mary 2 Samir Perlaza 3
1 MARACAS - Modèle et algorithmes pour des systèmes de communication fiables
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
3 NEO - Network Engineering and Operations
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper introduces an upper-bound on the absolute difference between: (a) the cumulative distribution function (c.d.f.) of the sum of a finite number of independent and identically distributed (i.i.d) random variables; and (b) a saddlepoint approximation of such c.d.f. This upperbound is general and particularly precise in the regime of large deviations. This result is used to study the dependence testing (DT) bound on the minimum decoding error probability (DEP) in memoryless channels. Within this context, the main results include new lower and upper bounds on the DT bound. As a byproduct, an upper bound on the absolute difference between the exact value of the DT bound and its saddlepoint approximation is obtained. Numerical analysis of these bounds are presented for the case of the binary symmetric channel and the additive white Gaussian noise channel, in which the new bounds are observed to be tight.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-02457361
Contributor : Dadja Anade Connect in order to contact the contributor
Submitted on : Tuesday, March 3, 2020 - 7:36:33 PM
Last modification on : Monday, May 16, 2022 - 4:54:01 PM
Long-term archiving on: : Thursday, June 4, 2020 - 5:47:24 PM
File
Dadja-ICC-Vfinal.pdf
Identifiers
  • HAL Id : hal-02457361, version 2
Citation
Dadja Anade, Jean-Marie Gorce, Philippe Mary, Samir Perlaza. On the saddlepoint approximation of the dependence testing bound in memoryless channels. IEEE International Conference on Communications, Jun 2020, Dublin, Ireland. pp.1-5. ⟨hal-02457361v2⟩
Share
Metrics
Record views
313
Files downloads
325
