On the Role of Similarity in Analogical Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Analogical transfer consists in making the assumption that if two situations are alike in some respect, they may be alike in others. This paper studies analogical transfer from the viewpoint of measurement theory. We show that analogical transfer can be seen as a similarity-based reasoning on "contour lines" in a qualitative similarity model: if a contour line is included in another at a given point, then it may also be included at other points that are not too (analogically) dissimilar.
iccbr.pdf (446.27 Ko) Télécharger le fichier
hal-02459103 , version 1 (29-01-2020)
  • HAL Id : hal-02459103 , version 1
Fadi Badra, Karima Sedki, Adrien Ugon. On the Role of Similarity in Analogical Transfer. ICCBR 2018 - 26th International Conference on Case-Based Reasoning, Jul 2018, Stockholm, France. ⟨hal-02459103⟩
66 Consultations
182 Téléchargements
