Tire forward and reverse supply chain design considering customer relationship management, Resources, Conservation & Recycling, pp.215-228, 2018. ,
An Interval parameter chance constrained programming model for uncertainty based decision making in tire retreading industry, Journal of Cleaner Production, pp.1-9, 2016. ,
The designing an environmentally conscious tire closed loop supply chain network with multiple recovery options using interactive fuzzy goal programming method, Applied Mathematical Modelling, pp.2661-2702, 2015. ,
The effects of uncertainty on a closed loop supply chain tire network, Expert Systems With Applications, 2017. ,
, , 2019.
What does Industry 4.0 mean to Supply Chain?, Manufacturing Engineering Society International Conference, pp.2351-9789, 2017. ,
Optimization Supply Chain Strategy of Tire Manufacturing using Goal Programming Method, SSRN eLibrary, 2018. ,
The Evolution of Closed-Loop Supply Chain Research, Institute for Operations Research and the Management Sciences (INFORMS), pp.10-18, 2009. ,
The analysis of closed loop supply chain using genetic algorithm and particle swarm optimisation method, International Journal of Production Research, vol.47, pp.1175-1200, 2009. ,
The review of Reverse Logistics and Closed Loop Supply Chains for Cleaner Production Focus, Journal of Cleaner Production, 2017. ,
Integrated forward and reverse supply chain: A tire case study, Waste Management, 2016. ,
Hybrid optimizers to solve a trilevel programming model for a tire closed-loop supply chain network design problem, Applied soft computing, 2018. ,
A multi-echelon reverse logistics network design for product recovery-a case of truck tire remanufacturing, International Journal Advance Manufacturing Technology, pp.1223-1234, 2010. ,
Research Gate -MILP, MIP and ILP, 2017. ,
Sustainable tire closed-loop supply chain network design: Hybrid metaheuristic algorithms for large-scale networks, Journal of Cleaner Production, vol.196, pp.273-296, 2018. ,
Optimal configuration of remanufacturing supply network with return quality decision, International Journal of Production Research, 2015. ,
Interval-parameter semi-infinite programming model for used tire management and planning under uncertainty, Computers & Industrial Engineering, 2017. ,
Reverse logistics network design under extended producer responsibility: The case of out-of-use tires in the Gran Santiago city of Chile, International journal of production economics, 2018. ,
A fuzzy goal programme with carbon tax policy for Brownfield Tyre remanufacturing, Journal of cleaner production, 2018. ,
Analyzing the past to prepare for the future : Writing a literature review, MIS Quarterly, vol.26, issue.2, 2002. ,
Conducting research literature reviews from internet to paper, 2014. ,
Adoption and implementation potential of the lean concept in the petroleum industry: state-of-the-art, International Journal of Lean Six Sigma, 2018. ,
Theory building through conceptual methods, International Journal of Operations, vol.13, issue.5, pp.3-11, 1993. ,
A stochastic multi-objective location-allocation-routing problem for tire supply chain considering sustainability aspects and quantity discounts, Journal of cleaner production, 2018. ,
Quantifying bullwhip effect in a closed loop supply chain, Operational Research Society of India, pp.231-253, 2011. ,
Product Return Management: Linking Product Returns, Closed-Loop Supply Chain Activities and the Effectiveness of the Reverse Supply Chains, Journal of Cleaner Production, 2017. ,
The multi echelon of reverse logistics network design for product recovery truck tire remanufacturing, Int J Adv Manuf Technol, pp.1223-1234, 2010. ,
