Conference papers
Understanding the Impact of User Behaviours and Scheduling Parameters on the Effectiveness of a Terminal Appointment System Using Discrete Event Simulation
Abstract : This research improves understanding of the impact of specific types of truck driver behaviour and temporal scheduling on the effectiveness of a terminal appointment system. A discrete event simulation model of a bulk cargo marine terminal is developed to analyse parameters related to driver behaviour (punctuality and proportion of planned appointments) and temporal scheduling (appointments per time window and time window spacing) on truck flows and turnaround times at the terminal. The model is based on an Australian wood chip export marine terminal currently experiencing significant truck congestion. The terminal operator and stakeholders have expressed interest in the implementation of an appointment system to address this issue. The modelling presented in this research was used to inform their investigation into developing an appointment system solution.Simulation results indicate that the proportion of planned appointments, used as a proxy for the appointment system use, has a significant impact on truck turnaround times. Greater truck arrival punctuality only marginally improves truck turnaround times. Interestingly most optimization approaches continue to focus on improving punctuality through service rules or financial penalties in order to achieve optimal turnaround times. However, the additional cost in terms of complexity or assumptions for optimal solutions against non-optimal approaches are rarely weighed in terms of dividends of the marginal improvements generated. By involving terminal users (drivers and transporters) in the design of an appointment system and its scheduling parameters, terminal operators can significantly improve appointment system use and effectiveness by increasing the probability of positive users’ behaviours.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-02460518
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, January 30, 2020 - 10:17:33 AM
Last modification on : Tuesday, February 23, 2021 - 7:24:06 PM
File
489108_1_En_3_Chapter.pdf
Identifiers
Citation
Mihai Neagoe, Hans-Henrik Hvolby, Mohammad Sadegh Taskhiri, Paul Turner. Understanding the Impact of User Behaviours and Scheduling Parameters on the Effectiveness of a Terminal Appointment System Using Discrete Event Simulation. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.27-34, ⟨10.1007/978-3-030-29996-5_3⟩. ⟨hal-02460518⟩
Share
Metrics
Record views
42
Files downloads
14
