Dynamic Scheduling of Parallel Heat Treatment Furnaces: A Case Study at a Manufacturing System, Journal of Manufacturing Systems, vol.46, pp.152-162, 2018. ,
Scheduling a Single Batch Processing Machine with Disagreeable Ready Times and Due Dates, International Journal of Industrial Engineering-Theory Applications and Practice, vol.10, issue.2, pp.175-187, 2003. ,
Minimizing Total Weighted Tardiness on Heterogeneous Batch Processors with Incompatible Job Families, International Journal of Advanced Manufacturing Technology, vol.70, issue.9, pp.1563-1578, 2014. ,
Hierarchical Production Planning and Real-Time Control for Parallel Batch Machines in a Flow Shop with Incompatible Jobs. Mathematical Problems in Engineering, 2018. ,
Scheduling Non-identical Parallel Batch Processing Machines to Minimize Total Weighted Tardiness using Particle Swarm Optimization, Computers & Industrial Engineering, vol.113, pp.425-436, 2017. ,
An ACO Algorithm for Makespan Minimization in Parallel Batch Machines with Non-identical Job Sizes and Incompatible Job Families, Applied Soft Computing, vol.38, pp.395-404, 2016. ,
Scheduling a Single Batch Processing Machine with Arbitrary Job Sizes and Incompatible Job Families, International Journal of Production Economics, vol.98, issue.1, pp.81-96, 2005. ,
A Genetic Algorithm for Minimizing Maximum Lateness on Parallel Identical Batch Processing Machines with Dynamic Job Arrivals and Incompatible Job Families, Computers and Operations Research, vol.34, issue.10, pp.3016-3028, 2007. ,
The Three-dimensional Bin Packing Problem, Operations Research, vol.48, issue.2, pp.256-267, 2000. ,
Modeling of Scheduling Batch Processor in Discrete Parts Manufacturing. A Chapter, Supply Chain Strategies, Issues and Models, pp.153-192, 2014. ,
Minimizing Total Weighted Tardiness on Heterogeneous Batch Processing Machines with Incompatible Job Families, International Journal of Advanced Manufacturing Technology, vol.28, issue.9, pp.1038-1047, 2006. ,
A Literature Review, Classification and Simple Meta-Analysis on Scheduling of Batch Processors in Semiconductor, International Journal of Advanced Manufacturing Technology, vol.29, issue.9, pp.990-1001, 2006. ,
A Survey of Problems, Solution Techniques, and Future Challenges in Scheduling Semiconductor Manufacturing Operations, Journal of Scheduling, vol.14, issue.6, pp.583-599, 2011. ,
Minimizing Makespan on a Single Heat-Treatment Furnace in Steel Casting Industry, International Journal of Services and Operations Management, vol.7, pp.112-142, 2010. ,
Heuristic Algorithms for Scheduling Heat-Treatment Furnace of Steel-Casting Foundry Manufacturing, International Journal of Advanced Operations Management, vol.3, pp.271-289, 2011. ,
A Mathematical Model for Scheduling a Batch Processing Machine with Multiple Incompatible Job Families, Non-identical Job dimensions, Nonidentical Job sizes, Non-agreeable Release Times and Due Dates, International Conference on Manufacturing, Optimization, Industrial and Material Engineering, 2013. ,
Integrated Batch Planning Optimization Based on Fuzzy Genetic and Constraint Satisfaction for Steel Production, International Journal of Simulation Modelling, vol.15, issue.1, pp.133-143, 2016. ,
A Genetic Algorithm to Minimize Maximum Lateness on a Batch Processing Machine, Computers and Operations Research, vol.29, issue.12, pp.1621-1640, 2002. ,
