Optimizing Workflow in Cell-Based Slaughtering and Cutting of Pigs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Johan Oppen
  • Fonction : Auteur
  • PersonId : 1063989
In this paper we describe and solve a scheduling problem taken from the slaughterhouse industry. In an on-going research project, a new concept for slaughtering and cutting of pigs is developed. The idea is to replace the traditional production line with a number of meat factory cells, where an operator slaughters and rough-cuts the pig, assisted by a robot. In order to minimize non-productive operator time, a solution approach is presented together with computational results.
489108_1_En_26_Chapter.pdf (241.63 Ko) Télécharger le fichier
hal-02460529 , version 1 (30-01-2020)
Paternité
Johan Oppen. Optimizing Workflow in Cell-Based Slaughtering and Cutting of Pigs. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.223-230, ⟨10.1007/978-3-030-29996-5_26⟩. ⟨hal-02460529⟩
50 Consultations
29 Téléchargements
