HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Robotic Deformable Object Cutting: From Simulation to Experimental Validation*
Abstract : In this paper, investigations into the robotic cutting of soft deformable materials are discussed. A force vision cooperative controller is proposed to deal with the object flexibility and uncertain modeling parameters. The control scheme is firstly tested within a simulator environment and then validated on an experimental cell. The construction of the simulator is described and the interaction with the deformable object discussed. Finally the results of the controller in simulation and experimentation are shown and the differences are discussed.
Document type :
Conference papers
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-02461913
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Friday, January 31, 2020 - 7:33:48 AM
Last modification on : Wednesday, April 27, 2022 - 3:50:07 AM
Long-term archiving on: : Friday, May 1, 2020 - 12:34:33 PM
File
ewdom14_long.pdf
Identifiers
  • HAL Id : hal-02461913, version 1
Citation
Philip Long, Wisama Khalil, Philippe Martinet. Robotic Deformable Object Cutting: From Simulation to Experimental Validation*. European Workshop on Deformable Object Manipulation, Mar 2014, Lyon, France. ⟨hal-02461913⟩
Share
Metrics
Record views
52
Files downloads
116
