Systematic errors in digital image correlation due to undermatched subset shape functions, Experimental Mechanics, vol.42, issue.3, pp.303-310, 2002. ,
The errors in digital image correlation due to overmatched shape functions, Measurement Science and Technology, vol.26, issue.4, p.45202, 2015. ,
Assessment of digital image correlation measurement errors: methodology and results, Experimental Mechanics, vol.49, issue.3, pp.353-370, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00881043
Formulation of Lucas-Kanade digital image correlation algorithms for noncontact deformation measurements: a review, Strain, vol.49, issue.4, pp.313-334, 2013. ,
Fourier-based interpolation bias prediction in digital image correlation, Optics Express, vol.23, issue.15, pp.19242-19260, 2015. ,
A fully integrated noise robust strategy for the identification of constitutive laws from digital images, Internation Journal for Numerical Methods in Engineering, vol.84, issue.6, pp.631-660, 2010. ,
Effect of interpolation on noise propagation from images to DIC displacement maps, International Journal for Numerical Methods in Engineering, vol.108, issue.3, pp.213-232, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01255944
Speckle pattern quality assessment for digital image correlation, Optics and Lasers in Engineering, vol.51, pp.1368-1378, 2013. ,
Quality assessment of speckle patterns for DIC by consideration of both systematic errors and random errors, Optics and Lasers in Engineering, vol.86, pp.132-142, 2016. ,
A review of speckle pattern fabrication and assessment for digital image correlation, Experimental Mechanics, vol.57, issue.8, pp.1161-1181, 2017. ,
Optimized digital speckle patterns for digital image correlation by consideration of both accuracy and efficiency, Applied Optics, vol.57, issue.4, pp.884-893, 2018. ,
Increasing accuracy and precision of digital image correlation through pattern optimization, Optics and Lasers in Engineering, vol.91, pp.73-85, 2017. ,
On the propagation of camera sensor noise to displacement maps obtained by DIC, Experimental Mechanics, vol.56, issue.6, pp.919-944, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01269655
Mean intensity gradient: an effective global parameter for quality assessment of the speckle patterns used in digital image correlation, Optics and Lasers in Engineering, vol.48, issue.4, pp.469-77, 2010. ,
Quality assessment of speckle patterns for digital image correlation, Optics and Lasers in Engineering, vol.44, issue.11, pp.1132-1145, 2006. ,
Optimized patterns for digital image correlation, Imaging Methods for Novel Materials and Challenging Applications, vol.3, 2012. ,
Closed-loop optimization of DIC speckle patterns based on simulated experiments, IEEE Transactions on Instrumentation and Measurement, pp.1-11, 2019. ,
A critical comparison of some metrological parameters characterizing local digital image correlation and grid method, Experimental Mechanics, vol.57, issue.3, pp.871-903, 2017. ,
Extracting displacement and strain fields from checkerboard images with the localized spectrum analysis, Experimental Mechanics, vol.59, issue.2, pp.207-218, 2019. ,
, International vocabulary of metrology. Basic and general concepts and associated terms, 2008.
Chapter 1. Basics of metrology and introduction to techniques, Full-field measurements and identification in solid mechanics, pp.1-29, 2012. ,
A self adaptive global digital image correlation algorithm, Experimental Mechanics, vol.55, issue.2, pp.361-378, 2015. ,
Ncorr: Open-source 2d digital image correlation matlab software, Experimental Mechanics, 2015. ,
Demodulation of spatial carrier images: Performance analysis of several algorithms, Experimental Mechanics, vol.53, issue.8, pp.1357-1370, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00834981
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, pp.716-734, 2013. ,
Image Correlation for Shape, Motion and Deformation Measurements. Basic Concepts, Theory and Applications, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01729219
On image gradients in digital image correlation, International Journal for Numerical Methods in Engineering, vol.105, issue.4, pp.243-260, 2016. ,
Influence of the analysis window on the metrological performance of the grid method, Journal of Mathematical Imaging and Vision, vol.56, issue.3, pp.472-498, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01298523
Linear and Nonlinear Models: Fixed Effects, Random Effects, and Mixed Models, 2006. ,
The grid method for in-plane displacement and strain measurement: a review and analysis, Strain, vol.52, issue.3, pp.205-243, 2016. ,
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00749804
A robust-to-noise deconvolution algorithm to enhance displacement and strain maps obtained by local DIC and LSA, Experimental Mechanics, vol.59, issue.2, pp.219-243, 2019. ,
Towards criteria characterizing the metrological performance of full-field measurement techniques. Application to the comparison between local and global versions of DIC, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02436541
All about speckles: Aliasing. Experimental Techniques, vol.38, pp.1-3, 2014. ,
Rendering deformed speckle images with a Boolean model, Journal of Mathematical Imaging and Vision, vol.60, issue.5, pp.634-650, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01664997
Update on the DIC challenge 2.0 and the stereo-DIC challenge, Proceedings of the conference, 2019. ,
Study on subset size selection in digital image correlation for speckle patterns, Optics Express, vol.16, issue.10, pp.7037-7048, 2008. ,
Quantitative error assessment in pattern matching: effects of intensity pattern noise, interpolation, strain and image contrast on motion measurements, Strain, vol.45, issue.2, pp.160-178, 2009. ,
Determining displacement and strain maps immune from aliasing effect with the grid method, Optics and Lasers in Engineering, vol.86, pp.317-328, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01352868
Practical Poissonian-Gaussian noise modeling and fitting for single-image raw-data, IEEE Transactions on Image Processing, vol.17, issue.10, pp.1737-1754, 2008. ,
Comparison of local and global approaches to digital image correlation, Experimental Mechanics, vol.52, issue.9, pp.1503-1519, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00750756
Smoothing and differentiation of data by simplified least-squares procedures, Analytical Chemistry, vol.36, issue.3, pp.1627-1639, 1964. ,
The effect of the ill-posed problem on quantitative error assessment in digital image correlation, Experimental Mechanics, 2017. ,
Pattern-induced bias in out-of-plane motion in digital image correlation, Proceedings of the conference, 2019. ,
Spatial DIC errors due to pattern-induced bias and grey level discretization, Experimental Mechanics, 2019. ,
On biases in displacement estimation for image registration, with a focus on photomechanics, 2019. ,
Producing and transferring low-spatial-frequency grids for measuring displacement fields with moiré and grid methods, Experimental Techniques, vol.28, issue.4, pp.23-26, 2004. ,
