Conference papers
Machine Learning Based Data Reduction in WSN for Smart Agriculture
Abstract : Nowadays, the agriculture domain faces a lot of challenges for a better usage of its natural resources. For this purpose, and for the increasing danger of climate change, there is a need to locally monitor meteorological data and soil conditions to help make quicker and more adapted decision for the culture. Wireless Sensor Networks (WSN) can serve as a monitoring system for those types of features. However, WSN suffer from the limited energy resources of the motes which shorten the lifetime of the overall network. Every mote periodically captures the monitored feature and sends the data to the sink for further analysis depending on a certain sampling rate. This process of sending big amount of data causes a high energy consumption of the sensor node and an important bandwidth usage on the network. In this paper, a Machine Learning based Data Reduction Algorithm (MLDR) is introduced. MLDR focuses on environmental data for the benefits of agriculture. MLDR is a data reduction approach which reduces the amount of transmitted data to the sink by adding some machine learning techniques at the sensor node level by keeping data availability and accuracy at the sink. This data reduction helps reduce the energy consumption and the bandwidth usage and it enhances the use of the medium while maintaining the accuracy of the information. This approach is validated through simulations on MATLAB using real temperature data-sets from Weather-Underground sensor network. Results show that the amount of sent data is reduced by more than 70% while maintaining a very good accuracy with a variance that did not surpass 2 degrees.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-02463167
Contributor : Christian Salim Connect in order to contact the contributor
Submitted on : Friday, January 31, 2020 - 5:27:44 PM
Last modification on : Thursday, January 20, 2022 - 5:26:42 PM
Long-term archiving on: : Friday, May 1, 2020 - 5:13:34 PM
File
Aina_conf_2020_CR.pdf
Identifiers
  • HAL Id : hal-02463167, version 1
Collections
Citation
Christian Salim, Nathalie Mitton. Machine Learning Based Data Reduction in WSN for Smart Agriculture. AINA 2020 - 34th International Conference on Advanced Information Networking and Applications, Apr 2020, Caserta, Italy. ⟨hal-02463167⟩
Share
Metrics
Record views
284
Files downloads
578
