HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Robotic Meat Cutting
Abstract : In this paper, the modeling, simulation and control of a robotic meat cutting cell is described. A multi-arm system is used in the separation task. A control scheme, using vision and force sensors, is proposed that copes with on-line object deformation. The control scheme and modeling process draws on those currently in use in the field of medical simulation. However the global objectives are fundamentally different. The contributions of this work are twofold. Firstly the modeling of a robotic cell that accurately represents the interactions and challenges of the meat cutting environment. Secondly, this cell is used as a pre-experimental testing system for a proposed multi-arm control scheme, exploiting vision, force and redundancy to complete the task.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02463414
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Friday, January 31, 2020 - 9:35:18 PM
Last modification on : Wednesday, April 27, 2022 - 3:43:41 AM
Identifiers
  • HAL Id : hal-02463414, version 1
Collections
Citation
Philip Long, Amine Moughlbay, Wisama Khalil, Philippe Martinet. Robotic Meat Cutting. ICT-PAMM Workshop, Nov 2013, Kumamoto, Japan. ⟨hal-02463414⟩
Share
Metrics
Record views
30
Files downloads
147
