Robust Newton solver based on variable switch for a finite volume discretization of Richards equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sabrina Bassetto
Guillaume Enchéry
  • Fonction : Auteur
  • PersonId : 930528
Quang Huy Tran
We propose an efficient nonlinear solver for the resolution of the Richards equation. It is based on variable switching and is easily implemented thanks to a fictitious variable allowing to describe both the saturation and the pressure. Numerical experiments show that our method enables to use Newton's method with large time steps, reasonable number of iterations and in regions where the pressure-saturation relationship is given by a graph.
BCET_FVCA9.pdf (1007.6 Ko) Télécharger le fichier
hal-02464945 , version 1 (03-02-2020)
  • HAL Id : hal-02464945 , version 1
Sabrina Bassetto, Clément Cancès, Guillaume Enchéry, Quang Huy Tran. Robust Newton solver based on variable switch for a finite volume discretization of Richards equation. Finite Volumes for Complex Applications IX, Jun 2020, Bergen, Norway. ⟨hal-02464945⟩
217 Consultations
203 Téléchargements
