Poster communications
Toward real-time embedded observer of unsteady fluid flow environment
Valentin Resseguier 1 Matheus Ladvig 1 Agustin M Picard 1 Etienne Mémin 2 Bertrand Chapron 3
2 FLUMINANCE - Fluid Flow Analysis, Description and Control from Image Sequences
IRMAR - Institut de Recherche Mathématique de Rennes, Inria Rennes – Bretagne Atlantique , INRAE - Institut National de Recherche pour l’Agriculture, l’Alimentation et l’Environnement
Abstract : For monitoring and actively controlling hydrodynamic and aerodynamic systems (e.g. aircraft wing), it can be necessary to estimate in real-time and predict the flow around those systems. We propose here a new method which combines data, physical models and measurements for this purpose. Very good numerical results have been obtained on 2- and 3-dimensional wake flows at moderate Reynolds, even 16 vortices shedding cycles after the learning window.
Complete list of metadata
https://hal.inria.fr/hal-02465508
Contributor : valentin resseguier Connect in order to contact the contributor
Submitted on : Monday, February 3, 2020 - 11:51:14 PM
Last modification on : Wednesday, June 1, 2022 - 3:27:40 AM
Long-term archiving on: : Monday, May 4, 2020 - 6:00:46 PM
File
Resseguier_ERTS.pdf
Identifiers
  • HAL Id : hal-02465508, version 1
Citation
Valentin Resseguier, Matheus Ladvig, Agustin M Picard, Etienne Mémin, Bertrand Chapron. Toward real-time embedded observer of unsteady fluid flow environment. ERTS 2020 - 10th European Congress Embedded Real Time Systems, Jan 2020, Toulouse, France. ⟨hal-02465508⟩
Share
Metrics
Record views
111
Files downloads
141
