Real time visual servoing, Proc. of the Int. IEEE Conference on Robotics and Automation, 1991. ,
Active P erception, 1993. ,
Choosing a Basis for Perceptual Space, Computer Vision Graphics and Image Processing, vol.29, issue.1, pp.87-99, 1985. ,
La relation vision-commande: th erorie et applications a des tâches robotiques, 1990. ,
Visual control of robot manipulators -A review, Visual Servoing, pp.1-31, 1993. ,
Lois de Commande pour le Controle et la Mobilit e de Machines Agricoles, LASMEA, 1996. ,
Model-Based Object Pose in 25 Lines of Code, International Journal of Computer Vison, vol.15, issue.2, pp.123-141, 1995. ,
Determination of the Attitude of 3D Objects from a Single Perspective Image, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.11, pp.1265-1278, 1989. ,
A new approach to visual servoing in robotics, IEEE Trans. on Robotics and Automation, vol.8, issue.3, pp.313-326, 1992. ,
Vision-guided servoing with feature-based trajectory generation, IEEE Trans. on Robotics and Automation, vol.5, issue.5, pp.691-700, 1989. ,
Robust Visual Servoing in 3-D Reaching Tasks, IEEE Trans. on Robotics and Automation, vol.12, issue.5, pp.732-742, 1996. ,
, IEEE Int. Conf. on Robotics and Automation, pp.22-28, 1996.
Visual Servoing, 1993. ,
An Analytic Solution For the Perspective 4 P oint Problem, CVGIP, issue.1, pp.33-44, 1989. ,
Object Pose : the Link between Weak Perspective, Para-Perspective, and Full Perspective, Int. Journal of Computer Vision, vol.22, issue.2, pp.173-189, 1997. ,
URL : https://hal.archives-ouvertes.fr/inria-00074321
Visual Servoing in Robotics Scheme Using a Camera/Laser-Stripe Sensor, IEEE Trans. on Robotics and Automation, vol.12, issue.5, pp.743-749, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-02465447
Perceptual Organization and Visual Recognition, 1985. ,
Robust Model-based Motion Tracking through the Integration of Search and Estimation, Int. Journal of Computer Vision, vol.8, issue.2, pp.113-122, 1992. ,
Use of rst derivative of geometric features in Visual Servoing, IEEE International Conference on Robotics and Automation, ICRA'96, 1996. ,
Vision Based Control Law using 3D Visual Features, World Automation Congress, vol.3, pp.497-502, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-02465451
Singularities in the determination of the situation, 1993. ,
URL : https://hal.archives-ouvertes.fr/inria-00074822
Couplage d'une cam era et d'un faisceau laser en Commande R ef erenc ee Vision, 1992. ,
Visual tracking of a moving target by a camera mounted on a robot: A combination of control and vision, IEEE Trans. on Robotics and Automation, vol.9, issue.1, pp.14-35, 1993. ,
Robot Control : The Task Function Approach, 1991. ,
Image-based visual servo c o n trol using relational graph error signals, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1074-1077, 1980. ,
Perspective Angle Transform and Its Application to 3-D Con guration Recovery, Proc. of Int. Conf. on Computer Vision and Pattern Recognition, pp.594-601, 1986. ,
Relative End-E ector Control Using Cartesian Position Based Visual Servoing, IEEE Trans. on Robotics and Automation, vol.12, issue.5, pp.684-696, 1996. ,
