Vision controlled robot for agricultural application, Proceedings of the 24 th ISIR, T okyo, pp.537-542, 1993. ,
Class of learning algorithms for multilayer perceptron, Proceedings of the SPIE. I n ternational Society for Optical Engineering, vol.1396, pp.237-242, 1991. ,
Texture parametrization method for image segmentation, Proceedings of Second European Conference on Computer Vision ECCV'92, pp.160-164, 1993. ,
La relation vision-commande : th eorie et application a d e s t aches robotiques. Th ese de PhD, 1990. ,
Positioning of a robot with respect to an object, tracking it and estimating its velocity b y visual servoing, Proceedings of the IEEE, International Conference o n R obotics and Automation, pp.2248-2253, 1991. ,
Neural Network Architectures: an introduction, Chap. The exclusive o r : a classic problem, 1990. ,
Development o f a visual guidance system for an upkeep robot of natural environments, Proceedings of the International Symposium on Signal Processing, pp.121-124, 1994. ,
Lois de Commande pour le Contrôle et la Mobilit e de Machines Agricoles. Th ese de PhD, 1996. ,
Vision guided mower for the upkeep of natural environment, Proceedings of the 1st International seminar of onmachine vision systems for the agricultural and bio-industries, pp.37-46, 1991. ,
Segmentation texturale originale appliqu ee au guidage visuel d'un robot d'entretien d'espaces naturels, Proceedings of the 14 eme colloque sur le traitement du signal et des images. GRETSI, pp.771-778, 1993. ,
Segmentation non supervis ee d'images textur ees par champs de Markov : Application a l'automatisation de l'entretien des espaces naturels. Th ese de PhD, 1993. ,
Image processing and algorithms merging : Real time control of an upkeep machine for natural spaces, Proceedings of the Fourth Workshop on Robotics in Agriculture and the Food-Industry, pp.93-98, 1995. ,
A new approach to visual servoing in robotics, IEEE Transactions on Robotics and Automation, vol.8, issue.3, pp.313-326, 1992. ,
Three Dimensionnal Computer Vision : A Geometric Viewpoint, 1993. ,
, Visual Servo Control. IEEE International Conference o n R obotics and Automation, 1996.
Etude d'un sous-syst eme de navigation pour un robot mobile, vol.783, 1988. ,
Error surfaces of multi-layer networks can have local minima T echnical report No 157, 1989. ,
Omniescient camera based outdoor mobile robot, Proceedings of the Workshop on Robotics in Agriculture a n d t h e F ood Industry. 1 st IARP, pp.247-258, 1990. ,
High-speed vehicle guidance based on vision, Control Eng. Practice, vol.2, issue.2, pp.287-297, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00548426
A partial Analysis of the High Speed Autonomous Navigation Problem, vol.9 ,
Linear control of high speed vehicle in image space, Proceedings of the Second International Conference on Industrial Automation. IAIA, Nancy, F rance, vol.2, pp.517-522, 1995. ,
Visual servoing in robotics scheme using a camera/laser-stripe sensor, IEEE Transactions on Robotics and Automation, vol.12, issue.5, pp.743-750, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-02465447
La Commande R ef erenc ee Vision pour le Guidage Automatique de V ehicules, 1996. ,
Guidance systems for agricultural vehicles, Proceedings of the 12 th World Congress on Agricultural Engineering. I n ternational Commission of Agricultural Engineering, pp.1136-1142, 1994. ,
Mod eles connexionnistes d'apprentissage. T h ese de PhD, 1987. ,
Nonholonomic motion planning: steering using sinusoids, IEEE Transactions on Automatic Control, vol.38, issue.5, pp.700-716, 1993. ,
, Robot Manipulators : Mathematics, Programming, and Control, vol.9, 2142.
Asservissement Visuel Appliqu e a u n Robot Mobile: etat de l'art et mod elisation cin ematique, 1991. ,
Parallel and Distributed P r ocessing, 1986. ,
Robot Control. The task function approach, pp.0-19, 1991. ,
URL : https://hal.archives-ouvertes.fr/inria-00071734
Visually guided operations in green houses, Proceedings of the Workshop on Robotics in Agriculture and the Food Industry. 1 st IARP, pp.69-84, 1990. ,
