HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
CP-DGPS based combine harvester control without orientation sensor
Abstract : Mobile robot control is a classic problem in the robotic community. It is particularly true in the agricultural field where repetitive tasks can be handled using AGV. In this paper, we address the problem of combine harvester control using a single CP-DGPS receiver, without any attitude measurement unit. A non linear, velocity independent control law has been designed. It relies upon the kinematic model of the combine harvester. Two approaches aimed at estimating the heading of the farm vehicle have been investigated. One uses GPS velocity measurements: the kinematic model of the harvester imposes that its linear velocity is directed along the vehicle axle. So the heading of the vehicle can be roughly estimated from raw velocity measurements. The other relies upon a Kalman state reconstructor and produces an indirect measurement of the heading. The reconstructor has been designed thanks to the kinematic model of the harvester, and taking into account for the sensor noise. The control law has been implemented on a combine harvester. Experiments have been carried out using both kinds of heading estimations on an almost flat ground. The standard deviation from the mean of the lateral position is about three centimeters, and the bias smaller than five centimeters. Both methods are compared an some conclusions are drawn.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-02465618
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Tuesday, February 4, 2020 - 8:12:00 AM
Last modification on : Friday, February 4, 2022 - 10:20:07 AM
Long-term archiving on: : Tuesday, May 5, 2020 - 1:21:54 PM
File
ion99.pdf
Identifiers
  • HAL Id : hal-02465618, version 1
Collections
Citation
Lionel Cordesses, Christophe Cariou, Philippe Martinet, Christian Thibaud. CP-DGPS based combine harvester control without orientation sensor. ION GPS 1999 - 12th International Technical Meeting of the Satellite Division of The Institute of Navigation, Sep 1999, Nashville, United States. pp.2041-2046. ⟨hal-02465618⟩
Share
Metrics
Record views
13
Files downloads
41
