Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Comparison of Visual Servoing Techniques : Experimental Results
Abstract : In visual servoing applications, two main approaches were de ned by Sanderson and Weiss at the beginning of the eighties: Position Based Control and Image Based Control. The aim of this article is to present di erent control laws using these approaches, and discuss the main advantages and disadvantages of both approaches through experimental results. The target object is composed of four non-coplanar characteristic points. From the projection of these four points in the image frame, the estimate of the Pose of the object in the sensor frame is computed using the Dementhon algorithm.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-02465626
Contributor : PHILIPPE MARTINET Connect in order to contact the contributor
Submitted on : Tuesday, February 4, 2020 - 8:18:20 AM
Last modification on : Friday, February 4, 2022 - 10:20:07 AM
Long-term archiving on: : Tuesday, May 5, 2020 - 12:52:17 PM
File
ecc99.pdf
Identifiers
Collections
Citation
Philippe Martinet. Comparison of Visual Servoing Techniques : Experimental Results. ECC 1999 - European Control Conference, Aug 1999, Karlsruhe, Germany. pp.4555-4560, ⟨10.23919/ECC.1999.7100053⟩. ⟨hal-02465626⟩
Share
Metrics
Record views
16
Files downloads
225
