, Les Robots Parallèles, 1997.
On the accuracy of a stewart platform -part I: the effect of manufacturing tolerances, Proc. of ICRA, pp.114-120, 1993. ,
Etalonnage géométrique des robots parallèles, 2000. ,
An effective kinematics calibration method for stewart platform, pp.87-92, 1994. ,
Method for kinematic calibration of stewart platforms, J. of Rob. Syst, vol.10, issue.3, pp.391-405, 1993. ,
Self calibration of Stewart-Gough parallel robots without extra sensors, IEEE Trans. On Rob. And Automation, vol.15, issue.16, pp.1116-1121, 1999. ,
Threedimensional metrology frame for precision applications, Precision Engineering, vol.23, pp.103-112 ,
A laser tracking system to measure position and orientation of robot end effectors under motion, The Int. J. of Robotics Research, vol.13, issue.4, pp.305-314, 1994. ,
Measurement of pose repeatability of Stewart platform, J. of Rob. Syst, vol.12, issue.12, pp.821-832, 1995. ,
A new sensor for the micrometrelevel measurement of three-dimensional dynamic contours, Meas. Science Technology, vol.10, pp.51-62, 1999. ,
Kinematic calibration of a Stewart platform using measurements obtained by a single theodolite, Proc. of IEEE Conf. On Intelligent Robots and Systems, pp.329-334, 1995. ,
A "3-2-1" kinematic configuration of a Stewart platform and its application to six degrees of freedom pose measurements, J. of Robotics and Computer Integrated Manufacturing, vol.11, issue.1, pp.23-34, 1994. ,
A 3-D sensor for parallel robot calibration, A parameter Perturbation Analysis, Recent Advances in Robot Kinematics, pp.451-460, 1996. ,
Kinematic calibration of the parallel delta robot, Robotica, vol.16, pp.207-218, 1998. ,
Visionbased kinematic calibration of a H4 parallel mechanism, ICRA, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-02466410
De la simplification et la résolution du modèle géométrique direct des robots parallèles, PhD Dissertation, 1995. ,
Calibration of robots having kinematic closed loops using non-linear least-squares estimation, Proc. IFToMM-jc Int. Symp. On Theory of Machine and Mechanisms, pp.153-158, 1992. ,
Self calibration of parallel mechanisms with a case study on Stewart platforms, IEEE Trans. On Robotics and Automation, vol.13, issue.3, pp.387-397, 1997. ,
Parallel manipulators, Part 2, Singular Configurations and Grassmann geometry, INRIA, 1988. ,
URL : https://hal.archives-ouvertes.fr/inria-00075760
A platform with six degrees of freedom, In: Proc. Instr. Mech. Engr, vol.180, pp.371-386, 1965. ,
A new technique for fully autonomous and efficient 3D robotics hand/eye calibration, IEEE Trans. On Rob. and Automation, vol.5, issue.3, pp.345-358, 1989. ,
Robot hand-eye calibration using structure-from-motion, Int. J. Robotics Research, vol.20, issue.3, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00520170
Three-dimensional Computer Vision: A Geometric Viewpoint, 1993. ,
Approximation in line space -applications in robot kinematics and surface reconstruction, Advances in Robot Kinematics: Analysis and Control, pp.403-412, 1998. ,
Determination of the attitude of 3-D objects from a single perspective view, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.11, issue.12, pp.1265-1278, 1989. ,
