HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Image-based Control of Mobile Robot with Central Catadioptric Cameras
Abstract : To close the loop between motion and vision, tracked visual features must remain in the camera field of view (visibility constraint). To overcome the visibility constraint , visual servoing methods can benefit from panoramic sensors such as catadioptric cameras (combining both mirrors and lenses). In this paper, we present a vision-based framework to control a nonholonomic mobile robot using a catadioptric imaging system. We particularly focus on a suitable catadioptric image-based control strategy of a nonholonomic robot in order to follow a 3D straight line. Such strategy can be applied to navigate in indoor or urban environment since the extraction and the tracking of straight lines are natural. First the control objectives are formulated in the catadioptric image space. The control law is then designed according to a well suited chained system for a mobile robot state vector directly expressed in the image space using a generic camera model. Simulation results illustrate the control strategy in the case of hypercatadioptric and paracatadioptric cameras. Index Terms-Omnidirectional vision, mobile robot control , visual servoing.
Document type :
Conference papers
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-02467141
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Wednesday, February 5, 2020 - 8:01:35 AM
Last modification on : Friday, April 15, 2022 - 11:08:03 AM
Long-term archiving on: : Wednesday, May 6, 2020 - 2:39:49 PM
File
icra05-hicham.pdf
Identifiers
Collections
Citation
Hicham Hadj Abdelkader, Y. Mezouar, Nicolas Andreff, Philippe Martinet. Image-based Control of Mobile Robot with Central Catadioptric Cameras. 2005 IEEE International Conference on Robotics and Automation, Apr 2005, Barcelona, Spain. pp.3522-3527, ⟨10.1109/ROBOT.2005.1570655⟩. ⟨hal-02467141⟩
Share
Metrics
Record views
29
Files downloads
168
