Visual servoing from lines, Int. Journal of Robotics Research, vol.21, issue.8, pp.679-700, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00590129
Vision-based kinematic calibration of an H4 parallel mechanism : practical accuracies, Industrial Robot : An international journal, vol.31, issue.3, pp.273-283, 2004. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00108586
The on-line direct kinematics of parallel manipulators under joint-sensor redundancy, Advances in Robot Kinematics, pp.126-137, 1998. ,
, La commande des robots manipulateurs, Traité IC2, chapter Asservissement visuel, pp.105-150, 2002.
, Int. Journal of Robotics Research -Special Issue on Visual Servoing, vol.22, 2003.
Force redundancy in parallel manipulators : theoretical and practical issues, Mech. Mach. Theory, vol.33, issue.6, pp.727-742, 1998. ,
Model-based object pose in 25 lines of code, Lecture Notes in Computer Science, pp.335-343, 1992. ,
A New Approach To Visual Servoing in Robotics, IEEE Trans. on Robotics and Automation, vol.8, issue.3, 1992. ,
Fully-isotropic T3R1-type parallel manipulator, On Advances in Robot Kinematics, volume Kluwer Academic Publishers, pp.265-272, 2004. ,
Universal tyre test machine, Proc. FISITA 9th Int. Technical Congress, pp.117-137, 1962. ,
Visually Guided Object Grasping, IEEE Transactions on Robotics and Automation, vol.14, issue.4, pp.525-532, 1998. ,
URL : https://hal.archives-ouvertes.fr/inria-00590088
An algorithm for solving the direct kinematics of general Gough-Stewart platforms, Mech. Mach. Theory, vol.31, issue.4, pp.365-380, 1996. ,
Vision based control in driving assistance of agricultural vehicles, Int. Journal of Robotics Research, vol.17, issue.10, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-02465578
Evaluation of a Cartesian parallel manipulator, Advances in Robot Kinematics : Theory and Applications, 2002. ,
Do we really need an accurate calibration pattern to achieve a reliable camera calibration, Proceedings of ECCV98, pp.158-174, 1998. ,
Visual servoing using linear features for under-actuated rigid-body dynamics, IEEE/RSJ Int. Conf. on Intelligent Robots Systems, 2001. ,
Intrinsics-free visual servoing with respect to straight lines, IEEE/RSJ Int. Conf. on Intelligent Robots Systems, 2002. ,
Commande cinématique référencée vision d'un robot parallèle de type plateforme de Gough, 2004. ,
Contributionà l'étude de l'apport de la redondance en robotique parallèle, 2002. ,
Vision based control law using 3d visual features, Proc. World Automation Congress, WAC'96, Robotics and Manufacturing Systems, vol.3, pp.497-502, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-02465451
An algorithm for the forward kinematics of general 6 d.o.f. parallel manipulators, INRIA, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00075229
Parallel robots, 2000. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
On a new geometry of space, Philosophical Transactions of the Royal Society of London, vol.155, pp.725-791, 1865. ,
Approximation in line space -applications in robot kinematics and surface reconstruction, Advances in Robot Kinematics : Analysis and Control, pp.403-412, 1998. ,
On vision-based kinematic calibration of a Stewart-Gough platform, 11th World Congress in Mechanism and Machine Science (IFToMM2003), pp.1906-1911, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-02466815
A platform with six degrees of freedom, Proc. IMechE, vol.180, pp.371-386, 1965. ,
Oriented Projective Geometry, 1991. ,
On the accuracy of a Stewart platform -Part I : The effect of manufacturing tolerances, Proc. ICRA93, pp.114-120, 1993. ,
Direct displacement analysis of parallel manipulators, Journal of Robotics Systems, vol.17, issue.6, pp.341-345, 2000. ,
