HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Visually Servoing a Gough-Stewart Parallel Robot Allows for Reduced and Linear Kinematic Calibration
Abstract : This paper focuses on the benefits of using computer vision to control a Gough-Stewart parallel robot. Namely, it is recalled that observing the legs of such a mechanism with a calibrated camera, thus following the redundant metrology paradigm, simplifies the control law. Then, we prove in this paper that such a control law depends on a reduced set of kinematic parameters (only those attached to the geometry of the robot base) and that these parameters can be obtained by solving a linear system. Moreover, we show that the camera can be calibrated without much experimental effort, simply using images of the robot itself. All this means that setting up the control system consists only in placing the camera in front of the robot.
Document type :
Conference papers
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-02467466
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Wednesday, February 5, 2020 - 7:12:02 AM
Last modification on : Thursday, March 3, 2022 - 8:08:03 PM
Long-term archiving on: : Wednesday, May 6, 2020 - 3:39:11 PM
File
icinco05-niko.pdf
Identifiers
Collections
Citation
Nicolas Andreff, Philippe Martinet. Visually Servoing a Gough-Stewart Parallel Robot Allows for Reduced and Linear Kinematic Calibration. ICINCO 2005 - 2nd International Conference on Informatics in Control, Automation and Robotics, Sep 2005, Barcelona, Spain. pp.119-124, ⟨10.5220/0001174301190124⟩. ⟨hal-02467466⟩
Share
Metrics
Record views
17
Files downloads
97
