Numerical modeling of floating potentials in electrokinetic problems using an asymptotic method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2020
Floating potentials appear in electrokinetic problems when isolated high conductive materials are included in a dielectric or weakly conductive ambient medium. The large contrast of conductivities generates numerical issues that make hard the computation of the electric potential. The paper proposes a rigorous numerical method to tackle such kind of problems. Interestingly, a correction to the case of perfect conductor is given in order to improve the accuracy of the computation. The method involves a cascade of two elementary problems set respectively in the ambient medium and in the high conductive inclusions. An example is proposed with a 4-electrode system designed to both induce electroporation in a biological tissue sample and measure the resulting impedance. The approach is extended to a nonlinear problem by taking advantage of the iterative scheme that is necessarily applied in this case.
202002IEEETM-VCCSP.pdf (472.02 Ko) Télécharger le fichier
hal-02467851 , version 1 (07-02-2020)
Damien Voyer, Sergio Corridore, Annabelle Collin, Riccardo Scorretti, Clair Poignard. Numerical modeling of floating potentials in electrokinetic problems using an asymptotic method. IEEE Transactions on Magnetics, 2020, ⟨10.1109/TMAG.2019.2951942⟩. ⟨hal-02467851⟩
74 Consultations
125 Téléchargements
