Parallel Robots, 2000. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
On the accuracy of a Stewart platform-Part I: The effect of manufacturing tolerances, Proc. IEEE Int. Conf. Robot. Autom, pp.114-120, 1993. ,
An algorithm for the forward kinematics of general 6 D.O.F. parallel manipulators INRIA, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00075229
An algorithm for solving the direct kinematics of general Gough-Stewart platforms, Mech. Mach. Theory, vol.31, issue.4, pp.365-380, 1996. ,
The Stewart-Gough platform of general geometry can have 40 real postures, Advances in Robot Kinematics: Analysis and Control, pp.1-10, 1998. ,
Universal tyre test machine, Proc. FISITA 9th Int, pp.117-137, 1962. ,
A platform with six degrees of freedom, Proc. IMechE, vol.180, pp.371-386, 1965. ,
Direct displacement analysis of parallel manipulators, J. Robot. Syst, vol.17, issue.6, pp.341-345, 2000. ,
Evaluation of a Cartesian parallel manipulator, Advances in Robot Kinematics: Theory and Applications, 2002. ,
Fully-isotropic T3Rl-type parallel manipulator, On Advances in Robot Kinematics, pp.265-272, 2004. ,
The on-line direct kinematics of parallel manipulators under joint-sensor redundancy, Advances in Robot Kinematics, pp.126-137, 1998. ,
Contribution à l'étude de l'apport de la redondance en robotique parallele, 2002. ,
Model-based object pose in 25 lines of code, Int. J. Comput. Vis, vol.15, issue.1, pp.123-141, 1995. ,
Do we really need an accurate calibration pattern to achieve a reliable camera calibration, Proc. ECCV, pp.158-174, 1998. ,
Vision-based kinematic calibration of an H4 parallel mechanism: Practical accuracies, Ind. Robot: An Int. J, vol.31, issue.3, pp.273-283, 2004. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00108586
Force redundancy in parallel manipulators: Theoretical and practical issues, Mech. Mach. Theory, vol.33, issue.6, pp.727-742, 1998. ,
A new approach to visual servoing in robotics, IEEE Trans. Robot. Autom, vol.8, issue.3, pp.313-326, 1992. ,
Vision based control law using 3D visual features, Proc. World Autom. Congr., Robot. Manuf. Syst, vol.3, pp.497-502, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-02465451
Visually guided object grasping, IEEE Trans. Robot. Autom, vol.14, issue.4, pp.525-532, 1998. ,
URL : https://hal.archives-ouvertes.fr/inria-00590088
, Int. J. Robot. Res. Special Issue Visual Servoing, vol.22, issue.10, 2003.
Visual servo control of a parallel manipulator for assembly tasks, Proc. 6th ,
, Int. Symp. Intell. Robot. Syst, pp.109-116, 1998.
A motion control scheme in task oriented coordinates and its robustness for parallel wire driven systems, Proc. Int. Conf, pp.545-550, 1999. ,
Three-dimensional position control of a parallel micromanipulator using visual servoing, Proc. SPIE, vol.4194, pp.103-111, 2000. ,
Kinematic calibration of parallel mechanisms: A novel approach using legs observation, IEEE Trans. Robot, vol.21, issue.4, pp.529-538, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00272609
On vision-based kinematic calibration of a Stewart-Gough platform, Proc. 11th ,
URL : https://hal.archives-ouvertes.fr/hal-02466815
, World Congr. Mech. Mach. Sci, pp.1906-1911, 2004.
Combining end-effector and legs observation for kinematic calibration of parallel mechanisms, Proc. IEEE Int. Conf. Robot. Autom, pp.4116-4121, 2004. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00108841
On a new geometry of space, Philos. Trans. Roy. Soc. London, vol.155, pp.725-791, 1865. ,
Algebraic Projective Geometry, 1952. ,
, Introduction to Theoretical Kinematics. Cambridge, 1990.
Approximation in line space-Applications in robot kinematics and surface reconstruction, Advances in Robot Kinematics: Analysis and Control, pp.403-412, 1998. ,
Three-Dimensional Computer Vision-A Geometric Viewpoint, ser, Artif. Intell.. Cambridge, 1993. ,
Visual servoing using linear features for under-actuated rigid-body dynamics, Proc. IEEE/RSJ Int. Conf. Intell. Robots Syst, pp.1153-1158, 2001. ,
Visual servoing from lines, Int. J. Robot. Res, vol.21, issue.8, pp.679-700, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00590129
Image-based visual servo control of aerial robotic systems using linear image features, IEEE Trans. Robot, vol.21, issue.2, pp.227-239, 2005. ,
Vision-based control of a Gough-Stewart parallel mechanism using legs observation, Proc. Int. Conf. Robot. Autom, pp.2546-2551, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02467186
On vision-based kinematic calibration of n legs parallel mechanisms, Proc. 13th ,
Identification, Rotterdam, The Netherlands, pp.977-982, 2003. ,
Close-range camera calibration, Photogram. Eng, vol.8, issue.37, pp.855-866, 1971. ,
An efficient and accurate calibration technique for 3D machine vision, Proc. Int. Conf. Comput. Vis. Pattern Recog, pp.364-374, 1986. ,
Camera calibration for 3D computer vision, Proc. Int. Workshop Mach, pp.240-247, 1987. ,
Straight lines have to be straight, Mach. Vis. Applic, vol.13, pp.14-24, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00267247
Intrinsics-free visual servoing with respect to straight lines, Proc. IEEE/RSJ Int. Conf. Intell. Robots Syst, pp.384-389, 2002. ,
Vision based control in driving assistance of agricultural vehicles, Int. J. Robot. Res, vol.17, issue.10, pp.1040-1054, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-02465578
Oriented Projective Geometry, 1991. ,
, Fundamentals of Robotic Mechanical Systems, 2002.
La commande des robots manipulateurs, Hermes, ch. Asservissement visuel, pp.105-150, 2002. ,
Dynamics of parallel manipulators by means of screw theory, Mech. Mach. Theory, vol.38, issue.11, pp.1113-1131, 2003. ,
Visual servoing of a Gough-Stewart parallel robot without proprioceptive sensors, Proc. 5th Int. Workshop Robot Motion, pp.225-230, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02467212
The 3D line motion matrix and alignment of line reconstructions, Int. J. Comput. Vis, vol.57, issue.3, pp.159-178, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00590146
ViSP for visual servoing: A generic software platform with a wide class of robot control skills, IEEE Robot. Autom. Mag, vol.12, issue.4, pp.40-52, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00351899
Simultaneous pose and velocity measurement for high-speed robots, Proc. IEEE Int. Conf. Robot. Autom, pp.3742-3747, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00100427
