Grasping objects: the cortical mechanisms of visuomotor transformation, Trends in Neuroscience, vol.18, issue.7, pp.314-320, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-00655238
The visual brain in action, 1995. ,
Differential effects of viewpoint on object-driven activation in dorsal and ventral streams, Neuron, vol.35, issue.4, pp.793-801, 2002. ,
A double dissociation between sensitivity to changes in object identity and orientation in the ventral and dorsal visual streams: A human fmri study, Neuropsychologia, 2005. ,
Dual-task interference is greater in memory-guided grasping than in visually guided grasping, Journal of Vision, vol.5, issue.8, p.361, 2005. ,
Modeling parietal-premotor interactions in primate control of grasping, Neural Networks, vol.11, issue.7-8, pp.1277-1303, 1998. ,
Computational Neuroscience of Vision, 2002. ,
Vision and grasping: Humans vs. robots," in Lecture Notes in Computer Science, pp.368-377, 2005. ,
Robotic grasping and contact: A review, Proc. IEEE Intl. Conf. on Robotics and Automation, pp.348-353, 2000. ,
Mechanics of form closure, ASME, 1978. ,
A fast and robust grasp planner for arbitrary 3D objects, Proc. IEEE Intl. Conf. on Robotics and Automation, pp.1890-1896, 1999. ,
Automatic grasp planning using shape primitives, Proc. IEEE Intl. Conf. on Robotics and Automation, pp.1824-1829, 2003. ,
Structure from controlled motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.5, pp.492-504, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00351862
Epipolar geometry from profiles under circular motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.6, pp.604-616, 2001. ,
Neural response to the perception of volume in the lateral occipital complex, Neuron, vol.29, issue.1, pp.277-286, 2001. ,
Neural correlates for perception of 3D surface orientation from texture gradient, Science, vol.298, issue.11, pp.409-412, 2002. ,
Visual features for characterizing robot grasp quality, IEEE Transactions on Systems, Man and Cybernetics, Part C, vol.35, issue.1, pp.30-41, 2005. ,
