Abstract : We study an approach for the optimization of spreading performed by centrifugal spreaders in order to minimize environmental effects due to application errors. Faced with a large scale problem, we divide the domain of study into subdomains so that each tramline is individually dealt with. In order to take into account the mechanical limits of the device, some inequality constraints are introduced. After cost function discretization, we use an augmented lagrangian algorithm associated with a L-BFGS technique to solve the problem. Results are presented for parallel and non parallel paths.
https://hal.inria.fr/hal-02468218 Contributor : Philippe MartinetConnect in order to contact the contributor Submitted on : Wednesday, February 5, 2020 - 3:52:44 PM Last modification on : Thursday, March 3, 2022 - 8:08:03 PM Long-term archiving on: : Wednesday, May 6, 2020 - 5:51:38 PM
Teddy Virin, Jonas Koko, Emmanuel Piron, Philippe Martinet, Michel Berducat. Spatial Optimization of Fertilizer Application by Centrifugal Spreading. STIC06 - 4ème Conférence STIC et Environnement, Apr 2006, Narbonne, France. ⟨hal-02468218⟩
