Constrained Optimization and Lagrange Multipliers Methods, 1982. ,
Mise en oeuvre de la directive 91/676/CEE -Pollution par les nitratesà partir de sources agricoles, 2005. ,
Representations of Quasi-Newton matrices and their use in limited memory methods, Mathematical Programming, vol.63, pp.129-156, 1994. ,
Etude du procédé d'épandage centrifuge d'engrais minéraux, 1997. ,
Optimal path nutrient application using variable rate technology, Proceedings of the 4 th European Conference on Prescision Agriculture, pp.171-176, 2003. ,
Fertilizer distribution modelling for centrifugal spreader design, 1997. ,
Performance of a continuously controlled spinning disc spreader for precision application of fertilizer, 1st European Conference on Precision Agriculture, pp.661-668, 1997. ,
