Constrained Optimization and Lagrange Multipliers Methods, 1982. ,
Mise en oeuvre de la directive 91/676/cee -pollution par les nitrates a partir de sources agricoles, 2005. ,
Representations of quasi-newton matrices and their use in limited memory methods, Mathematical Programming, vol.63, pp.129-156, 1994. ,
Optimal path nutrient application using variable rate technology, Proc. of the Four th European Conference on Precision Agriculture, pp.171-176, 2003. ,
Mineral Fertilizer Use and the Environment, 1998. ,
ISO 5690/1 Equipment for distributing fertilizers -Test methods -Part 1: Full width fertilizer distributors. International Organization for Standardization, 1985. ,
Fertilizer distribution modelling for centrifugal spreader design, 1997. ,
Performance of fertiliser spreading equipment for precision agriculture applications, 1st International Symposium on Centrifugal Fertiliser Spreading, pp.10-18, 2005. ,
