S341.3 Procedure for Measuring Distribution Uniformity and Calibrating Granular Broadcast Spreaders, 2001. ,
Constrained Optimization and Lagrange Multipliers Methods, 1982. ,
Representations of quasi-newton matrices and their use in limited memory methods, Mathematical Programming, vol.63, pp.129-156, 1994. ,
Etude du procede d'epandage centrifuge d'engrais mineraux, 1997. ,
Optimal path nutrient application using variable rate technology, Proc. of the Four th European Conference on Precision Agriculture, pp.171-176, 2003. ,
Mineral Fertilizer Use and the Environment, 1998. ,
Fertilizer distribution modelling for centrifugal spreader design, 1997. ,
Performance of a continuously controlled spinning disc spreader for precision application of fertilizer. In: 1st European Conference on Precision Agriculture, pp.661-668, 1997. ,
Performance of fertiliser spreading equipment for precision agriculture applications, 1st International Symposium on Centrifugal Fertiliser Spreading, pp.10-18, 2005. ,
