Parallel Robots, 2000. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
PAR4: very high speed parallel robot for pick-and-place, IEEE International Conference on Intelligent Robots and Systems (IROS'05), pp.1202-1207, 2005. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00106125
Still a long way to go on the road for parallel mechanisms, ASME 27th Biennial Mechanisms and Robotics Conference, 2002. ,
Non linear PD control for trajectory tracking with consideration of the design for control methodology, IEEE International Conference on Robotics and Automation (ICRA'02), pp.4126-4131, 2002. ,
Application of a nonlinear adaptative controller to a 6 dof parallel manipulator, IEEE International Conference on Robotics and Automation (ICRA'00), pp.1930-1935, 2000. ,
Adapted time-optimal trajectory planning for parallel manipulators with full dynamic modelling, IEEE International Conference on Robotics and Automation (ICRA'05), pp.411-416, 2005. ,
A new method for tuning PID parameters of a 3-DOF reconfigurable parallel kinematic machine, IEEE International Conference on Robotics and Automation (ICRA'04), pp.2249-2254, 2004. ,
Modeling, identification and control of robots, 2002. ,
Series-parallel Dualities in Actively Coordinated Mechanisms, The International Journal of Robotics Research, vol.10, issue.2, pp.473-480, 1991. ,
3d pose visual servoing relieves parallel robot control from joint sensing, International Conference on Intelligent Robots and Systems (IROS'06), 2006. ,
An algorithm for solving the direct kinematic of the Gough-Stewart platforms, 1994. ,
Working modes and aspects in fully parallel manipulators, IEEE International Conference on Robotics and Automation (ICRA'98), pp.1964-1969, 1998. ,
Hybrid control of a twoarm robot handling firmly a single rigid object, 2nd International Workshop on Sensorial Integration for Industerial Robots (SIFIR'89), pp.67-62, 1989. ,
A laser tracking system to measure position and orientation of robot end-effectors under motion, The International Journal of Robotic Research, vol.13, issue.4, pp.305-314, 1994. ,
Asservissements visuels rapides d'un robot manipulateur a six degrés de libertés, Suivi de cible et de profilé, 1999. ,
Simultaneous object pose and velocity computation using a single view from a rolling shutter camera, European Conference on Computer Vision (ECCV), pp.56-68, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00095087
I4: a new parallel mechanism for scara motions, IEEE International Conference on Robotics and Automation (ICRA'03), pp.1875-1881, 2003. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00269505
Fully-isotropic T3R1-type parallel manipulators, On Advances In Robot Kinematics, pp.265-272, 2004. ,
Solving the froward kinematic of a Gough-type parallel manipulator with interval analysis, The International Journal of Robotic Research, vol.23, issue.3, pp.221-235, 2004. ,
Enhancing parallel robot with redundant sensors, International Conference on Robotics and Automation (ICRA'02), pp.4114-4119, 2002. ,
The direct kinematics of parallel manipulators under joint-sensor redundancy, IEEE Transactions on Robotics and Automation, vol.16, issue.1, pp.1-8, 2000. ,
On the accuracy of a Stewart platformpart I: The effect of manufacturing tolerances, IEEE International Conference on Robotics and Automation (ICRA'93), pp.114-120, 1993. ,
Self calibration of Gough platform using leg mobility constraints, World congress on the theory of machine and mechanisms, pp.104-109, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00906476
General solution for the dynamic modeling of parallel robots, IEEE International Conference on Robotics and Automation (ICRA'04), pp.3665-3670, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00401684
A general strategy based on the Newton-Euler approach for the dynamic formulation of parallel manipulators. Mechanism and Machine Theory, vol.34, pp.801-824, 1999. ,
Advanced position and force control concepts for the linear direct driven hexapod PaLiDA, The fifth Chemnitz Parallel Kinematics Seminar, pp.359-378, 2006. ,
Extended Kalman filtering and weighted least squares dynamic identification of robot, Control Engineering Pratice, vol.9, issue.12, pp.1361-1372, 2001. ,
A new method for estimating parameters of a dynamic robot model, IEEE Transactions on Robotics and Automation, vol.17, issue.1, pp.95-100, 2001. ,
Resolved acceleration control of mechanical manipulators, IEEE Transactions on Automatic Control, AC, vol.25, issue.3, pp.468-474, 1980. ,
Predictive functionnal control of a parallel robot, IEEE International Conference on Intelligent Robots and Systems (IROS'03), pp.2785-2790, 2003. ,
Control design for a Stewart platform using small workspace characteristics, IEEE International Conference on Intelligent Robots and Systems (IROS'01), pp.2184-2189, 2001. ,
Precision study of a decoupled four degrees of freedom parallel robot including manufacturing and assembling errors, International Conference on Integrated Design and Manufacturing in Mechanical Engineering (IDMME'06), 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00118649
