EASYPAP: a Framework for Learning Parallel Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Alice Lasserre
  • Fonction : Auteur
  • PersonId : 1064384
Raymond Namyst
This paper presents EASYPAP, an easy-to-use programming environment designed to help students to learn parallel programming. EASYPAP features a wide range of 2D computation kernels that the students are invited to parallelize using Pthreads, OpenMP, OpenCL or MPI. Execution of kernels can be interactively visualized, and powerful monitoring tools allow students to observe both the scheduling of computations and the assignment of 2D tiles to threads/processes. By focusing on algorithms and data distribution, students can experiment with diverse code variants and tune multiple parameters, resulting in richer problem exploration and faster progress towards efficient solutions. We present selected lab assignments which illustrate how EASYPAP improves the way students explore parallel programming.
edupar.pdf (1.6 Mo) Télécharger le fichier
hal-02469919 , version 1 (06-02-2020)
  • HAL Id : hal-02469919 , version 1
Alice Lasserre, Raymond Namyst, Pierre-André Wacrenier. EASYPAP: a Framework for Learning Parallel Programming. 2020. ⟨hal-02469919⟩
Collections
CNRS INRIA INRIA2
274 Consultations
299 Téléchargements
