SmartWatts: Self-Calibrating Software-Defined Power Meter for Containers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fine-grained power monitoring of software activities becomes unavoidable to maximize the power usage efficiency of data centers. In particular, achieving an optimal scheduling of containers requires the deployment of software-defined power~meters to go beyond the granularity of hardware power monitoring sensors, such as Power Distribution Units (PDU) or Intel's Running Average Power Limit (RAPL), to deliver power estimations of activities at the granularity of software~containers. However, the definition of the underlying power models that estimate the power consumption remains a long and fragile process that is tightly coupled to the host machine. To overcome these limitations, this paper introduces SmartWatts: a lightweight power monitoring system that adopts online calibration to automatically adjust the CPU and DRAM power models in order to maximize the accuracy of runtime power estimations of containers. Unlike state-of-the-art techniques, SmartWatts does not require any a priori training phase or hardware equipment to configure the power models and can therefore be deployed on a wide range of machines including the latest power optimizations, at no cost.
smartwatts-paper.pdf (1.25 Mo) Télécharger le fichier
hal-02470128 , version 1 (23-06-2020)
Guillaume Fieni, Romain Rouvoy, Lionel Seinturier. SmartWatts: Self-Calibrating Software-Defined Power Meter for Containers. CCGRID 2020 - 20th IEEE/ACM International Symposium on Cluster, Cloud and Internet Computing, May 2020, Melbourne, Australia. ⟨10.1109/CCGrid49817.2020.00-45⟩. ⟨hal-02470128⟩
1502 Consultations
783 Téléchargements
