Toward good families of codes from towers of surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce in this article a new method to estimate the minimum distance of codes from algebraic surfaces. This lower bound is generic, i.e. can be applied to any surface, and turns out to be "liftable" under finite morphisms, paving the way toward the construction of good codes from towers of surfaces. In the same direction, we establish a criterion for a surface with a fixed finite set of closed points $\mathcal P$ to have an infinite tower of $\ell$-\'etale covers in which $\mathcal P$ splits totally. We conclude by stating several open problems. In particular, we relate the existence of asymptotically good codes from general type surfaces with a very ample canonical class to the behaviour of their number of rational points with respect to their $K^2$ and coherent Euler characteristic.
hal-02470343 , version 1 (07-02-2020)
Alain Couvreur, Philippe Lebacque, Marc Perret. Toward good families of codes from towers of surfaces. Arithmetic, Geometry, Cryptography and Coding Theory, Stéphane Ballet, Gaetan Bisson, Irene Bouw, Jun 2019, Marseille, France. ⟨10.1090/conm/770⟩. ⟨hal-02470343⟩
102 Consultations
0 Téléchargements
