Alternative Split Functions and Dekker's Product
We introduce algorithms for splitting a positive binary floating-point number into two numbers of around half the system precision, using arithmetic operations all rounded either toward −∞ or toward +∞. We use these algorithms to compute "exact" products (i.e., to express the product of two floating-point numbers as the unevaluated sum of two floating-point numbers, the rounded product and an error term). This is similar to the classical Dekker product, adapted here to directed roundings.
SplitDirectedRoundings.pdf (115.07 Ko)
Télécharger le fichier
arith2020-code.tar.gz (6.96 Ko)
