Toward real-time embedded observer of unsteady fluid flow environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Valentin Resseguier
Matheus Ladvig
  • Fonction : Auteur
Augustin Picard
  • Fonction : Auteur
  • PersonId : 917534
For monitoring and actively controlling hydrodynamic and aerodynamic systems (e.g. aircraft wing), it can be necessary to estimate in real-time and predict the flow around those systems. We propose here a new method which combines data, physical models and measurements for this purpose. Very good numerical results have been obtained on 2-and 3-dimensional wake flows at moderate Reynolds, even 16 vortices shedding cycles after the learning window.
Abstract_Resseguier_et_al_ERTS.pdf (837.18 Ko) Télécharger le fichier
hal-02471456 , version 1 (08-02-2020)
  • HAL Id : hal-02471456 , version 1
Valentin Resseguier, Matheus Ladvig, Augustin Picard, Etienne Mémin, Bertrand Chapron. Toward real-time embedded observer of unsteady fluid flow environment. 10th European Congress on Embedded Real Time Software and Systems (ERTS 2020), Jan 2020, Toulouse, France. ⟨hal-02471456⟩
169 Consultations
145 Téléchargements
