Toward real-time embedded observer of unsteady fluid flow environment
For monitoring and actively controlling hydrodynamic and aerodynamic systems (e.g. aircraft wing), it can be necessary to estimate in real-time and predict the flow around those systems. We propose here a new method which combines data, physical models and measurements for this purpose. Very good numerical results have been obtained on 2-and 3-dimensional wake flows at moderate Reynolds, even 16 vortices shedding cycles after the learning window.
