Flexible image-based photometric reconstruction using virtual light sources, Comput. Graph. Forum, vol.20, 2001. ,
Point light source estimation based on scenes recorded by a rgb-d camera, British Machine Vision Conference, 2013. ,
Realtime estimation of illumination direction for augmented reality on mobile devices, Color and Imaging Conference, pp.111-116, 2012. ,
Rendering synthetic objects into real scenes: Bridging traditional and image-based graphics with global illumination and high dynamic range photography, Proceedings of the 25th ,
, Annual Conference on Computer Graphics and Interactive Techniques, pp.189-198, 1998.
Interactive near-field illumination for photorealistic augmented reality on mobile devices, IEEE Int. Symp. on Mixed and Augmented Reality, pp.29-38, 2014. ,
3d high dynamic range dense visual slam and its application to real-time object relighting, pp.143-152, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01357357
Spatially varying image based lighting using hdrvideo, vol.37, pp.923-934, 2013. ,
Photorealistic rendering of mixed reality scenes, vol.34, pp.643-665, 2015. ,
Determining reflectance parameters and illumination distribution from a sparse set of images for view-dependent image synthesis, IEEE Int. Conf. on Computer Vision, vol.1, pp.599-606, 2001. ,
Real-time surface lightfield capture for augmentation of planar specular surfaces, IEEE Int. Symp. on Mixed and Augmented Reality, pp.91-97, 2012. ,
Illumination distribution from brightness in shadows: Adaptive estimation of illumination distribution with unknown reflectance properties in shadow regions, Proceedings of the ICCV, vol.2, p.1999 ,
Illumination from shadows, IEEE on Pattern Analysis and Machine Intelligence, vol.25, issue.3, pp.290-300, 2003. ,
Robust shadow and illumination estimation using a mixture model, IEEE Conf. on Computer Vision and Pattern Recognition, pp.651-658, 2009. ,
Illumination estimation and cast shadow detection through a higherorder graphical model, IEEE Conf. on Computer Vision and Pattern Recognition, pp.673-680, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00856316
Estimation of position and intensity of dynamic light sources using cast shadows on textured real surfaces, IEEE Int. Conf. on Image Processing, pp.1063-1067, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01815195
Light source estimation using feature points from specular highlights and cast shadows," in Int, Journal of Physical Sciences, vol.11, pp.168-177, 2016. ,
Multiple-cue illumination estimation in textured scenes, IEEE Int. Conf. on Computer Vision, 2003. ,
Learning to predict indoor illumination from a single image, vol.36, 2017. ,
Learning to reconstruct shape and spatially-varying reflectance from a single image, vol.12, pp.1-11, 2018. ,
Fast spatially-varying indoor lighting estimation, IEEE Conference on Computer Vision and Pattern Recognition, 2019. ,
Neural illumination: Lighting prediction for indoor environments, IEEE Conference on Computer Vision and Pattern Recognition, 2019. ,
Deep light source estimation for mixed reality, 2018. ,
Automatic scene inference for 3d object compositing, vol.33, pp.1-15, 2014. ,
Illumination for computer generated pictures, Commun. ACM, vol.18, issue.6, pp.311-317, 1975. ,
A fast white balance algorithm based on pixel greyness, Signal, Image and Video Processing, vol.11, pp.525-532, 2017. ,
Automatic detection and elimination of specular reflectance in color images by means of ms diagram and vector connected filters, IEEE on Systems, Man, and Cybernetics, vol.36, pp.681-687, 2006. ,
On the detection of dominant points on digital curves, IEEE on Pattern Analysis and Machine Intelligence, vol.11, pp.859-872, 1989. ,
Semantic 3D Object Maps for Everyday Manipulation in Human Living Environments, 2009. ,
, Digital Color Imaging Handbook, 2002.
