Character Segmentation in Asian Collector's Seal Imprints: An Attempt to Retrieval Based on Ancient Character Typeface - Archive ouverte HAL Access content directly
Journal Articles Journal of Data Mining and Digital Humanities Year : 2021
(1) , (2) , (3)
1
2
3
Collector's seals provide important clues about the ownership of a book. They contain much information pertaining to the essential elements of ancient materials and also show the details of possession, its relation to the book, the identity of the collectors and their social status and wealth, amongst others. Asian collectors have typically used artistic ancient characters rather than modern ones to make their seals. In addition to the owner's name, several other words are used to express more profound meanings. A system that automatically recognizes these characters can help enthusiasts and professionals better understand the background information of these seals. However, there is a lack of training data and labelled images, as samples of some seals are scarce and most of them are degraded images. It is necessary to find new ways to make full use of such scarce data. While these data are available online, they do not contain information on the characters' position. The goal of this research is to assist in obtaining more labelled data through user interaction and provide retrieval tools that use only standard character typefaces extracted from font files. In this paper, a character segmentation method is proposed to predict the candidate characters' area without any labelled training data that contain character coordinate information. A retrieval-based recognition system that focuses on a single character is also proposed to support seal retrieval and matching. The experimental results demonstrate that the proposed character segmentation method performs well on Asian collector's seals, with 85% of the test data being correctly segmented.
(12.17_final)Character Segmentation in Collector_ (2).pdf (6.99 Mo) Télécharger le fichier
Dates and versions
hal-02476910 , version 1 (13-02-2020)
hal-02476910 , version 2 (13-02-2020)
hal-02476910 , version 3 (15-05-2020)
hal-02476910 , version 4 (21-09-2020)
hal-02476910 , version 5 (17-12-2020)
Identifiers
Cite
Kangying Li, Biligsaikhan Batjargal, Akira Maeda. Character Segmentation in Asian Collector's Seal Imprints: An Attempt to Retrieval Based on Ancient Character Typeface. Journal of Data Mining and Digital Humanities, 2021, HistoInformatics, ⟨10.46298/jdmdh.6102⟩. ⟨hal-02476910v5⟩
156 View
663 Download
Share
