Effects of microgeometry and surface relaxation onNMR pulsed-field-gradient experiments: Simple pore geometries, Physical Review B, vol.453, issue.1, pp.143-156, 1992. ,
Abundance of cell bodies can explain the stickmodel's failure to describe high b-value diffusion signal in grey matter, Proc. Int. Soc.Magn. Reson. Med, p.1096, 2018. ,
On the scaling behav-ior of water diffusion in human brain white matter, NeuroImage, vol.185, pp.379-387, 2019. ,
Simu-lation of Echo Attenuation form Molecules in Spheres and between Planes, 1993. ,
Modeling diffusion of intracel-lular metabolites in the mouse brain up to very high diffusion-weighting: Diffusion inlong fibers (almost) accounts for non-monoexponential attenuation: Modeling Diffusionof Brain Metabolites in Vivo up to Very High Diffusion Weighting, Magnetic Resonancein Medicine, vol.77, issue.1, pp.343-350, 2017. ,
MAPL: Tissue microstructure estimation using Laplacian-regularizedMAP-MRI and its application to HCP data, NeuroImage, vol.134, pp.365-385, 2016. ,
Pulsed-field-gradient NMR measurements of restricted diffusion and thereturn-to-origin probability, Journal of Magnetic Resonance, vol.114, pp.47-58, 1995. ,
Rotationally-invariant mapping of scalar and orientational metrics ,
