Punctual Hilbert Schemes and Certified Approximate Singularities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper we provide a new method to certify that a nearby polynomial system has a singular isolated root with a prescribed multiplicity structure. More precisely, given a polynomial system f $=(f_1, \ldots, f_N)\in C[x_1, \ldots, x_n]^N$, we present a Newton iteration on an extended deflated system that locally converges, under regularity conditions, to a small deformation of $f$ such that this deformed system has an exact singular root. The iteration simultaneously converges to the coordinates of the singular root and the coefficients of the so called inverse system that describes the multiplicity structure at the root. We use $α$-theory test to certify the quadratic convergence, and togive bounds on the size of the deformation and on the approximation error. The approach relies on an analysis of the punctual Hilbert scheme, for which we provide a new description. We show in particular that some of its strata can be rationally parametrized and exploit these parametrizations in the certification. We show in numerical experimentation how the approximate inverse system can be computed as a starting point of the Newton iterations and the fast numerical convergence to the singular root with its multiplicity structure, certified by our criteria.
paper.pdf (312.37 Ko) Télécharger le fichier
hal-02478768 , version 1 (14-02-2020)
hal-02478768 , version 2 (30-06-2020)
Angelos Mantzaflaris, Bernard Mourrain, Agnes Szanto. Punctual Hilbert Schemes and Certified Approximate Singularities. 2020. ⟨hal-02478768v1⟩
188 Consultations
223 Téléchargements
